Why is my 1600mhz ram 1333 mhz?
Go to solution Solved by i_build_nanosuits,
@Square554
That's the standard settings that every motherboard sets RAM to at first. You have to go into the BIOS and set the XMP profile that your RAM is advertised with manually.
who cares...
change it in the bios
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
I recommend this video by JayzTwoCents on how to fix that.
nvrmind. ninja'd
Edited by PathfinderNC
Motherboard: MSI 770-C45 2606Mhz HT 200Mhz Bclk | CPU: AMD Phenom II x4 955 BE 3606Mhz | GPU: ASUS R9 270 DCU2 2GB 1125MHz Core 1500Mhz vRAM
RAM: HyperX Black PC3-12800 1600MHz 9-9-9-20 | Storage: HyperX 3K 120GB SSD SATA II + 570GB| PSU: EVGA 500B 500W
F@H Stats: 7,077,384pts x 576wu (08/14/2015)        green=stock setting     red=above spec     blue=below spec
System Name: Rocinante = "workhorse"
Yeah my corsair vengeance 1600mhz Blue 8gb kit ram did that. tbh, i haven't noticed a performance increase since i set it to 1600 instead of the default 1333.
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
