So, I went to 3 speed testing services, all of them say that I should getting 4.20 Mb/s.
But when I download through Steam, or uTorrent, I am downloading with a speed of 500 Kb/s.
I dont know why, when im downloading I am not watching any movies and I have a wired connection.
Please help me with this.
https://linustechtips.com/topic/205261-slow-download-speed/
because the speed meausuring sites give the speed in Kb/s and Steam / uTorrent give the speed in KB/s so it actually works out correctly with a bit being an eight of a byte.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/205261-slow-download-speed/#findComment-2786166
utorrent and steam are giving you your speed in KB/s so thats about right
https://linustechtips.com/topic/205261-slow-download-speed/#findComment-2786179
that 4.2 is megaBITS. megabits divided by 8 is megabytes.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/205261-slow-download-speed/#findComment-2786192
And KB/s is same as Mb/S?
BTW, im not a techie when it comes to internet.
Basically 1KB/s is the same as 8Kb/s
https://linustechtips.com/topic/205261-slow-download-speed/#findComment-2786660
  • 1 month later...
There are lot of factors that affects your download speed like router problem,Simultaneously   if you run lot of software's,There may be  a chance of virus attack  in your system etc..So try to check everything and all.
If you have slow download speed,Try to keep in mind the following instructions
1.Get a download accelerator
2.Turn off all unused apps while downloading
3.Don't upload information while you're downloading
4.Make sure your router is free of any interference
5.Update your network device driver
6.You must always keep your computer clean of any viruses
7.clear your temporary download history files.
8.Use latest version of any browser
9.Do regular speed test.
When i had the same problem,i followed the same ways.I am sure,it's very useful to increase your download speed.Then you can check your new internet speed using ScanmySpeed.com
https://linustechtips.com/topic/205261-slow-download-speed/#findComment-3081216
