looking for a laptop help
Solved by D2ultima,
http://www.xoticpc.com/sager-np7338-clevo-w230ss-p-6992.html?wconfigure=yes
Select IC Diamond thermal compound, the 1TB 7200RPM free upgrade and the Wireless 7260ac card and you're good to go. If you have a little more you could grab a mSATA SSD or an OS. It should be fine and is a 13" so it'll be pretty portable.
PopsicleHustler ·
Posted in Audio2 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory10 -
11
play_circle_filled
Latest From ShortCircuit:
