I'm torn between this case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811235035
and this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119263
I think the Z11 looks way cooler but it has less features than the Storm Scout.
I am also open to suggestions on other cases in the $90 or less range.
Other than that I will go with the one that wins.
Muffinator
https://linustechtips.com/topic/20466-im-torn-help-me-out/
Get the cooler master one, has more/better cable management and more usable features that actually matter
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/20466-im-torn-help-me-out/#findComment-243890
I'd also say go with the Cooler Master because it has better features and the Zalman Z11 isn't that good from what I've heard.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/20466-im-torn-help-me-out/#findComment-243895
Second one.
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/20466-im-torn-help-me-out/#findComment-243899
Storm scout looks better and has better features imo.
It's the red leds, isn't it?
https://linustechtips.com/topic/20466-im-torn-help-me-out/#findComment-244022
hmmm it seems there's a general consensus from the looks of things. (i.e. 13-0 in favor of the scout :P)
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
https://linustechtips.com/topic/20466-im-torn-help-me-out/#findComment-244037
Scout 2, better in every way
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/20466-im-torn-help-me-out/#findComment-244285
Doing a Red/Black theme.
The phantom 410 comes in both red, black and other colours, and I'd say it's better than the storm scout 2 because of the built in fan controlle, the fan mounts inside the case (if you like that), and imo looks better than the scout 2.
Red:http://www.newegg.com/Product/Product.aspx?Item=N82E16811146086
Black:http://www.newegg.com/Product/Product.aspx?Item=N82E16811146085
Murphy's Law: "Anything that can go wrong, will go wrong"
https://linustechtips.com/topic/20466-im-torn-help-me-out/#findComment-244317
Z11 looks awesome! But if you plan water cooling the CM is better. However, Z11 can be moded fairly easy for H100 or H110.
Cable managemen is more challenging on Z11 but not impossible. With the rest of the money buy a fan controler and you will be ok.
FX8320 4.2Ghz@1.280v& 4.5 Ghz Turbo@1.312v Thermalright HR-02/w TY-147 140MM+Arctic Cooling 120MMVRM cooled by AMD Stock Cooler Fan 70MM 0-7200 RPM PWM controlled via SpeedfanGigabyte GA990XA-UD3Gigabyte HD 7970 SOC@R9 280X120GiBee Kingston HyperX 3K2TB Toshiba DT01ACA2001TB WD GreenZalman Z11+Enermax 140MM TB Apollish RED+2X Deepcool 120MM and stock fans running @5VSingle Channel Patriot 8GB (1333MHZ)+Dual Channel 4GB&2GB Kingston NANO Gaming(1600MHZ CL9)=14GB 1,600 Jigahurtz 10-10-9-29 CR1@1.28VSirtec High Power 500WASUS Xonar DG, Logitech F510Sony MDR-XD200Edifier X220 + Edifier 3200A4Tech XL-747H 3600dpiA4Tech X7-200MPdecent membrane keyboardPhilips 236V3LSB 23" 1080p@71Hz .
Sorry for my English....
https://linustechtips.com/topic/20466-im-torn-help-me-out/#findComment-245649
The Cooler Master case has that removable hard drive cage and that may be significant in the future or now if you are using or in the future planning to use extremely long graphics cards.  I would say both cases look great and well both have USB 3.0 so that is good.  Another nice feature of the Cooler Master case is the handle so it is easy to take to a LAN party or hell just to a friend's place or relatives during the holidays so you have something to do if the visit gets too boring.  A computer case really is a very personal choice though and I bet you I could find many more cases that you might be interested in and some would be cheaper but really for this part of the computer you have to look at the case all the time so make sure you are satisfied with how it looks to you.
Oh but damn the Zalman is $30 less after a rebate card so really is it fair to compare these cases ?  Honestly the Zalman case would be my choice if the cards I was going to be putting in it would fit no problem.
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/20466-im-torn-help-me-out/#findComment-246525
I hate rebates. You have to spend the money to get it, and then the money you get back you have to spend on the brand that you purchased it from.
Muffinator
https://linustechtips.com/topic/20466-im-torn-help-me-out/#findComment-247738
Both are atrocious IMO, but if it has to be one of those, go with the Scout. You're going to regret it when you grow up though :P
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/20466-im-torn-help-me-out/#findComment-247984
