I've ben wondering how many watts do i need for the following build, and if someone has any suggestions for PSU thats gonna last me.(80+ bronze if possible or better) Anyway's, here's the hardware:
GPU: ASUS R9-280
Motherboard: ASRock Fatality
CPU: Intel i7 4770K  3.4GHZ- 3.9GHZ turbo
SSD: Crucial M500
HDD:WD Black 1TB 7200rpm 64 mb cache
RAM: 2x4 GB 1600MHZ  DDR3 CL9
Optical: Standard DVD/RW
Fans: 3x 120mm regular, 2x120mm LED fans
The wattage i get on some PSU calculator are about 430W, and if someone can suggest some power supply's for this build i would be very gratefull!
https://linustechtips.com/topic/204635-how-many-watts-do-i-need/
550ish watts
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
https://linustechtips.com/topic/204635-how-many-watts-do-i-need/#findComment-2778783
Also I'd recommend a corsair CS or RM series depending on whether you want a modular or semi-modular, and how much noise you want
CPU: R9 5900X----GPU: RX 7900 XTX ------MOBO: ROG X570E-------RAM: CORSAIR VENGANCE 32GB-------PSU: SEASONIC 1000W-------CASE: LIAN LI O11D XL ROG
https://linustechtips.com/topic/204635-how-many-watts-do-i-need/#findComment-2778808
550 watts at least. nothing worse then your room filling up with the smell of hot plastic from a weak psu.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
https://linustechtips.com/topic/204635-how-many-watts-do-i-need/#findComment-2783901
I am buying it from the internet.
My budget was around 80€ for the psu
These are all very good psu's. The Superflower is non modular. The Seasonic and XFX are semi modular.
http://de.pcpartpicker.com/part/super-flower-power-supply-sf650p14xehx
http://de.pcpartpicker.com/part/xfx-power-supply-p1650xxxb9
http://de.pcpartpicker.com/part/seasonic-power-supply-ssr550rm
https://linustechtips.com/topic/204635-how-many-watts-do-i-need/#findComment-2784966
I dont buy it from a tippical site i buy it by model i search for example on amazon for psu and then search for the best price anf buy it there
The XFX Core 550W or the XFX TS 550W (depending on budget) will be more than enough to power this system.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/204635-how-many-watts-do-i-need/#findComment-2786264
