Desktop or Laptop?
If Desktop, than what thekeemo said. For laptop, I can only say from my own experience that the batteries of a Macbook last for ever. You can leave that thing on standby for like a month and it will just drain a little bit.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770285
If its for school then I suggest a Mac. Never "buy" a PC unless you gonna build one
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770293
Mac for school. They are so light. Or a chromebook if you can't afford one.
Case:Define R4 | MOBO:ASRock z75 Pro 3 | CPU:i7-3770k 4.0GHz | CPU Cooler:H100i | GPU:970 Strix | RAM:Hyper X 16GB |
Peripherals:ATH-M50x Limited Blue Edition | K95 RGB | M65 RGB | Blue Yeti MIC | (3x)1920x2080 Acer Monitors
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770306
Desktop or Laptop?
If Desktop, than what thekeemo said. For laptop use, I can only say from my own experience that the batteries of a Macbook last for ever. You can leave that thing on standby for like a month and it will just drain a little bit.
it is going to be a laptop
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770317
Mac
What they said :D #MacbookMASTERRACE!!!
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770326
Desktop or Laptop?
What kind of schoolwork
im going to be working a lot with movies and video editing next year
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770342
Are these comments all a joke? Am I missing something?
13" Macbook Pro i7 (I7-3520M) | 16gb RAM | 128gb Sandisk SSD
Current build------------------------------Future build↓
Intel Core i7-4790K 3.5GHz Quad-Core | G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3 | Asus GTX 970 Strix | Corsair 450D ATX Mid Tower | EVGA SuperNOVA 750 | MSI Z97-GAMING 5 ATX LGA1150 | 128gb Sandisk SSD | Corsair H90 94.0 CFM Liquid
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770365
What level of Video editing. iMovie or Pro stuff? For 1080p a Macbook Pro is totaly fine. I have used one for years to edit Videos. But I upgraded to PC, because iMovie has limited functionality. You can do green screen and all that stuff with iMovie though.
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770374
Got a budget though? The cheapest macbook has a i3 and it's about 800 dollars. It's also clocked at 2.7 GHz turbo, 1.3 default
I wouldn't buy a PC for simple school work.
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770384
I thought this was a joke. Why wouldn't you? I bought a Macbook Pro before getting into tech and all the money I spent on this could have gone towards an epic gaming desktop and a good school laptop. They are just soooo expensive for what you get.
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770404
I was wondering the same thing. When did Macs become necessary for school over Windows?
Have you ever used a Macbook on the go? Compared to Windows they seem to be much superior, especially if you have to make it through school with one charge. But for Desktops Windows wins.
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770405
it is going to be imovie level stuff  :D
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770406
Much more convenient.
I don't understand how a Macbook is more convenient. There's literally no benefit of a Macbook over a slim Windows-based laptop. If anything you get more for your money with a Windows-based laptop.
Yes I have and I couldn't stand it. There's literally nothing Mac OSX can do that makes Windows look inferior.
I used to have an M14X laptop and I would easily get more battery life out of it compared to my friend's 13" Macbook.
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770416
I would rather get a slim macbook for school. Just get a macbook pro with an i7 and install windows 8.1 on it if you'd ever need anything on it
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770419
Yeah you know... Getting dem specs for school, right? No not really, I'd rather get a macbook air, even with it's weak specs.
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770424
Than a Macbook is a great option.
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770433
well money is not a problem at the moment also why i wanted to switch my old windows pc for something new
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770434
100% genuine.
If you have the cash to splash get a MacBook it will perform the same in 2 years that it does today and the battery will last you forever. I have a 2 year old 15" MacBook Pro Retina and it has not let me down even once.
https://linustechtips.com/topic/204027-i-need-your-help-guys/#findComment-2770440
