I'm deciding to get a speedlite for my Nikon D5100, but i can't choose which ones are the best in terms of just using it indoors in a party or at any event. I figured that i might aswell get one as the standard flash that is attached to the camera is too weak for my liking when taking pictures with a zoom lens (55-300mm), and the lens appears in the photo because of the flash.
Note though, i don't want an official nikon speedlite as they're too expensive, there are third party ones made by neewer and meike etc. but i can't decide which one to buy. Preferably, i would like it to cost under £30. As i've been looking and most of them are under £50.
Thanks in advance,
Sean.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/203835-dslr-flash-speedlite-options/
http://www.amazon.com/Neewer-Speedlite-Panasonic-Fujifilm-single-contact/dp/B004LEAYXY/ref=sr_1_3?ie=UTF8&qid=1408992616&sr=8-3&keywords=neewer+tt650
Lol was also looking at this.. highly regarded. I recommend doing research with your camera.
is that manual or does it have TTL?
Old Rig
Seems its manual TTL seems to cost a bit more.
which is better for just indoor event photos? TTL or manual?
manual sounds harder to do as you gotta correctly set every setting for it to be a good photo. i may be wrong though, kinda new to these speedlites/flashguns.
Old Rig
If you aren't up to speed with flashes, using manual can be a PITA. I mean, I used grey cards and test fire a few times while hooked up to my laptop to ensure the light is right, and then I start using it. Plus you're gonna need a decent flash meter just to get proper manual settings.
TTL lens is the best purchase. Has everything you need and most have very robust auto modes.
