I have a 600 watts PSU. I'm planning to upgrade from a 660 to an r9 290 (with the kraken g10 and h55) and i was wondering do i have enough power?
Specs:
I5 4440
H87 g43 MOBO
6 fans (3 sp 120s 2 red LED fans and 1 stock fan)
2 1TB WD hard drive
250GB samsung evo SSD
1 dvd rom
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/203612-would-there-be-enough-power/
You should be fine. If it's a branded PSU, and at least 80~ Bronze.
A 750W would be more ideal though.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
Depends. If your PSU is 80+ certified and from a reliable manufacturer than yes. Otherwise you should upgrade your PSU before getting that graphics card.
Yes if it's a good (80+ certified) PSU.
Yeap! it is from cooler master with 80+ bronze :D (sorry for the late reply web didnt notify me D:) Alright thanks guys :)
what model is the PSU?
is it under the V or VSM series?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
It's the G600W!
It's the G600W!
that is fine currently
but be sure to get a better PSU with the 290
So it isnt enough for the 290?? D:
the wattage just ok only
the actual wattage is much lower than you think
you need to invest like the higher VSM 650 watt unit since you are going to water cool your 290 and OC it
so i cant go the route of watercooling and OCing? D:
not with your current PSU
But after using a power supply calculator (not including the OC and liquid cooling) im only pulling around 443 watts of power! Does ocing and a h55 really take up to 150watts of power?
with a good quality PSU 600 watts is fine
but that PSU has a high chance of failure at higher wattage draw
like i said before, your current PSU is do not output even close to 600 watts
it like 500+ watts
and when you OC you need more power to sustain those clocks, more heat will be produce and you need all the cooling you need to bring the 290 heat under control
an OC 290 can exceed 300+ watts at peak loads
it like 500+ watts
It does have a 80+ bronze tho..... Its that bad?
it only means like how good it can convert the current from 230 volts to 12 volts without losing power and waste as heat
nothing related to the wattage
think of how air-conditioning ratings works
http://www.coolermaster.com/powersupply/office-home-g-series/g600/
I know! But i thought the overhead room is 50watts? so a 600 W PSU shd atleast spew out 550 watts at all times right?
nope it cant reach 550 watts
it like 500+ before the PSU starts crapping on you
only the 2 series which is the V and VSM are the good PSU to use from the CoolerMaster range
http://www.coolermaster.com/powersupply/v-sm-series/v650s/
http://www.coolermaster.com/powersupply/v-series/v700/
so i'll be better off not going the liquid cooling way? D: can i atleast OC? :o
only small amounts
if i were you
i will not risk running such any expensive GPU with a low end PSU
only small amounts
if i were you
The person at simlim scammed me darn it... i got this PSU for a hundred bucks
if you need a new PSU get it from PCThemes 4th floor or from TradePac 5th floor back alley shop run by the Indian boss
i got my MOBO and CPU from pc themes..... but best bargains seems to be a nice shop too!
Oh ya I'll ask the forum again for more opinions about this (hope it doesnt offend you :x)
that shop is ok, i buy my SD cards from there as they are the cheapest
avoid cybermind and bizgram as the prices they sell their items are crazy expensive
video pro was my preferred shop but when they shifted to the 5th floor
the prices of their product when up too
Heck man tell that to fuwell. i got my 660 for $330 zzzzzzz
