Something is loose inside.
Unless you know how to take one apart and fix it, I suggest just leaving a heavy weight on top to stop the rattle.
https://linustechtips.com/topic/203599-subwoofer-rattle/#findComment-2764167
Get a Bigger sub i recommend 13' up i love my 15's :D Get one of these http://www.sonicelectronix.com/item_38100_Earthquake-Sound-HoleeS-15.html
it will satisfy you garnuteed
Ha, that price isn't very appealing though. For a computer speaker set up... That would be a little hard to power. Lol
https://linustechtips.com/topic/203599-subwoofer-rattle/#findComment-2764566
Lol, he ask for a fix to his sub rattling and you recommend getting a new sub?
And 15's are pure overkill for PC audio. A 6-8' is plenty.
https://linustechtips.com/topic/203599-subwoofer-rattle/#findComment-2769862
only 8'?????????????? my dekstop speakers are quad 14 inch 2 front 2 back,
https://linustechtips.com/topic/203599-subwoofer-rattle/#findComment-2769889
Let me guess, you have a matching 2000 watt amplifier? A proper designed 8" will go deep and loud enough, there is no point in having 15's in your room other than bragging rights.
Anyway, that's not what OP asked. There is a possibilty that there's something loose, but it could be the driver itself; did you abuse your sub mechanically?
https://linustechtips.com/topic/203599-subwoofer-rattle/#findComment-2769964
yey, i actully found the amp on the side of the street :D, and yeah probbly does have smothing loose
https://linustechtips.com/topic/203599-subwoofer-rattle/#findComment-2769977
Dat 32' organ stop tho.
https://linustechtips.com/topic/203599-subwoofer-rattle/#findComment-2770031
