Video card help
Go to solution Solved by flibberdipper,
The 780, since XFX is meh.
Hello! This is my first time posting on these forums, so this may not be posted in the correct place but i have a question for my build.
I am deciding on two graphics cards currently, the XFX Black Edition R9 290( http://www.ncixus.com/products/?sku=93750&promoid=1046 ) or the Asus Direct CU II GTX 780 http://www.newegg.com/Product/Product.aspx?Item=N82E16814121779
i just need help on deciding which one to go for.
if you have any suggestions for other graphics cards in that price range ($425-475) it would be very helpful.
https://linustechtips.com/topic/203511-video-card-help/
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/203511-video-card-help/#findComment-2762858
The 780 will get you better performance but the r9 is cheaper, your choice. Either way they will both play games exceptionally well
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/203511-video-card-help/#findComment-2762976
Oh don't feel any need to explain...
Anyway, either card would be great I am however leaning on the side of the 780 simply due to the quality of ASUS components and the features it offers. Again the 290 is a great card that, if you chose it over the 780, has a great cooler and would still perform well but not quite as well. :)
https://linustechtips.com/topic/203511-video-card-help/#findComment-2763127
Don't get the xfx. Get either the tri-x or vapor-x from sapphire if you want to OC. The 780 is simply not worth the extra cash. http://www.ncix.com/detail/sapphire-r9-290-edition-1000mhz-ac-94897-1046.htm
i7 7700k @ 4.9ghz | Asus Maximus IX Hero | G.skill 32gb @ 3200 | Gtx 1080 classified | In win 909 | Samsung 960 pro 1tb | WD caviar blue 1tb x3 | Dell u3417w | Corsair H115i | Ducky premier dk9008p (mx reds) | Logitech g900 | Sennheiser hd 800s w/ hdvd 800 | Audioengine a5+ w/ s8
https://linustechtips.com/topic/203511-video-card-help/#findComment-2763219
780.  I'm kinda partial to Nvidia, but it is a really good card and Nvidia has some nice features like Geforce experience, g-sync, adaptive v-sync and such. the 290 is a great card as well, but doesn't perform quite as well as the 780.
I don't know what you're smoking man. They are virtually neck and neck at 1080p, at 1440p the 290 pulls ahead by a significant margin because it has 4gb of vram.
https://linustechtips.com/topic/203511-video-card-help/#findComment-2763284
I'm not smoking anything.  I'm saying how the 780 is good.  Through research after you're very harsh comment, I do realize that the 290 is better, especially if you bump up the resolution, but I do still feel the 780 is a worthwhile card.
https://linustechtips.com/topic/203511-video-card-help/#findComment-2777068
