So my old wireless adapter for my 360 controller shit it a few days ago and I've been thinking it's about time I moved on to a new controller instead of purchasing a new adapter.
I want some recommendations based on my preferences: I only really have one recommendation and that's the format: I MUST have the left analog stick in the higher position and the right analog stick in the lower position such as how the Xbox controller is laid out. I find this to be most comfortable for me and I really dislike the dualshock design.
Let's say price isn't an issue, what's the best controllers out there with this layout?
I'd like multiple options  :)
Also I'm aware purchasing an adpater is the cheapest route but I'm just bored of looking at the 360 controller.
CPU: Intel Core i5 4460 | GPU: XFX r9 280x DD BLACK OC EDITION | RAM: 8gb Kingston HyperX Fury 1600Mhz | Mobo: Gigabyte h97n-WIFI | PSU: EVGA 600B | Case: Cooler Master Elite 120 | Cooler: Stock intel | SSD: Samsung 840 EVO 120gb | Storage: WD 150 gb
CPU: Intel Core i7 4710MQ | GPU: NVIDIA Geforce GTX 850M | RAM: 8gb Corsair 1600Mhz | Mobo: Metabox WA50SJ Motherboard | Case: Metabox WA50SJ case | Cooler: Stock | SSD: Sandisk 256gb
:wub:  :wub:  :wub:
Best purchase this year, bcuz forza
If you have a micro USB cable, getting a PS4 controller can work, although you have to install some 3rd party software
Razer Sabertooth is another recommendation that I personally would get.... If i used controllers.
I use keyboard and mouse, another suggestion that you probably already have :)
*Please no hate comments about the keyboard and mouse bit*
My friend praises the Xbox One quite heavily for his PC; although i could never replace my wired vanilla 360 controller.
System: 5930K, MSI X99 SLI PLUS, GTX 780Ti (SLI),  840 EVO, Fractal R4 (Full Custom Loop)  (IP)
Media Server/Perm Folder: i3 4130, CX500, 4 X WD Red 1TB, 60GB Adata SSD for boot, Node 304, ASrock Z87-E ITX, 8GB Kingston Value Ram
