Hello everyone!
I am on a $150 budget for an upgrae!
I am upgrading my CPU and Mobo and I need help.
Can anyone send a list of a good $150 upgrade?
More info: My friend recommended me an FX 6300 processor which is $107 in amazon.
If there is a good mobo combo with the FX 6300, I would really appreciate it!
Thank you all~
Specs:
CPU: A4-3420
GPU: GTX 660 MSI OC
RAM: 6GB DDR3 1600MHz
PSU: 500w EVGA 80 plus (Not Bronze)
OS: Windows 8
https://linustechtips.com/topic/203003-150-upgrade-help/
Hello everyone!
Thank you all~
Specs:
CPU: A4-3420
GPU: GTX 660 MSI OC
OS: Windows 8
The Pentium is a better CPU if youre gaming and much cheaper Im not a fanboy i tell it how it is. I would suggest getting that + a hyper 212 evo if you want to overclock and z87/z97 pc mate mobo both are cheap.
MY RIG | AMD FX-8320 | COOLER MASTER HYPER 212 EVO | ASUS M5A97 R2.0 | CRUCIAL BALLISTIX SPORT 8GB DDR3-1600MHz | WD CAVIAR BLUE 1TB | ASUS RADEON R9 280 3GB DIRECTCU II | CORSAIR 300R | CORSAIR CX 600W 80+ BRONZE | 1x COOLER MASTER SICKLEFLOW 120mm | WINDOWS 7 ULTIMATE 64-BIT | DELL S2240M 21.5' 1080p <p> | G602 | G710+ MOBILE| ONEPLUS ONE 64GB RUNNING OXYGENOS  | NEXUS 4 16GB RUNNING LOLLIPOP | NEXUS 7 2013 32GB RUNNING LOLLIPOP
https://linustechtips.com/topic/203003-150-upgrade-help/#findComment-2755836
@Grimmeh 6 GB Is terrible choice for gaming
if you still want FX 6300 i can do but over 7$
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($108.00 @ Newegg)
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard  ($49.79 @ Newegg)
Total: $157.79
Generated by PCPartPicker 2014-08-24 00:23 EDT-0400
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/203003-150-upgrade-help/#findComment-2756591
