Need new headphone(s) and a mic 600 CAD max
Solved by IBIubbleTea,
I am pretty set for the mod-mic 4.0
The DT 770s looks great but dosen't look very portable at 250omhs but those could definitely do for my desktop headphones
A900x would do well for portable ? Dosen't look as hard to drive. And i would be open to try/consider open headphones if they are that much better
The A900x are 42 ohms and the DT770 has different versions, 32, 80, 250 ohms. if you get the DT770 32 ohms, your phone or what not could drive them better than the A900x, i.e louder. Both should be fine for home use unless you have a really old computer.
