Hey Guys so...
I used to own a tablet and it broke so I got a credit from the store and bought a laptop about a year ago..
Its a HP(horrible product ;) ) and basically terrible. Its a AMD 1.4ghz processor and it had 2gb of ram. I upgraded the ram to 4gb but its still S***.
My question is if you look at the picture I've included you can see that 99% of my CPU and only 75% of my ram are being used. All I'm trying to do at the moment is watch one YouTube video at 480p but it keeps stopping and starting because my CPU cant keep up. I have a 4gb ram stick laying around. Is there any chance whatsoever that the laptop will benefit from upgrading the Ram to 6gb. The reason I ask is that the laptop is pretty much impossible to take apart because both the harddrive and the ram are right on the bottom of the laptop under the motherboard. You actually have to take the whole laptop apart to get to them.. wtf...
Performance Pic..
http://i.imgur.com/OrtwWuI.png
Any answers appreciated.. even if you want to laugh at me for having the worst laptop ever made.. :)
https://linustechtips.com/topic/202529-terrible-laptop-help/
have ddr3-1600 ram for dual channel because it would be faster and would help a bit
http://www.overclock.net/t/1269500/amd-apu-laptops-and-memory-sensitivity-i-e-why-you-need-to-choose-an-apu-laptop-with-a-dual-channel-ddr3-1600-config
here's a chart about it
I have a hp laptop and the performance isn't that bad because it's a quad core
https://linustechtips.com/topic/202529-terrible-laptop-help/#findComment-2747996
nope. if your cpu is at 99% nothing will help. I would say the only option is to install linux on that.
laptop itself is not bad, it's the chip that's in that laptop, it's completely your fault for buying the cheapest thing.
it's a E1-1200, that thing is like a mobile phone chip, can't expect much.
https://linustechtips.com/topic/202529-terrible-laptop-help/#findComment-2748013
Hey Guys so...
The, under the mobo stuff, is why I charge people extra when they ask me to repair/upgrade HP laptops... they are such a pain to deal with.
"Any sufficiently advanced technology is indistinguishable from magic" - Arthur C. Clarke
Just because it may seem like magic, I'm not a wizard, just a nerd. I am fallible.
Use the quote button or @<username> to reply to people | Mark solved troubleshooting topics as such, selecting the correct answer, and follow them to get replies!
Community Standards | Guides & Tutorials Troubleshooting Section
https://linustechtips.com/topic/202529-terrible-laptop-help/#findComment-2748027
Yeahh I understand It's my fault. At least I still have my PC. :)
https://linustechtips.com/topic/202529-terrible-laptop-help/#findComment-2748082
You do, although, it's a basically useless laptop, unless you want to install Chrome OS or Linux on it. The CPU is just... underpowered, and the RAM is far too low for anyone on this forum to get decent usage out of it without being infuriated.
https://linustechtips.com/topic/202529-terrible-laptop-help/#findComment-2748087
I don't understand why they do it. Laptops I've dealt with in the past you take 4 screws out of the bottom and the hardrive and ram are sitting right on top. They make somthing so easy hard. I guess they don't want you messing with it?
https://linustechtips.com/topic/202529-terrible-laptop-help/#findComment-2748097
they don't expect anyone to try and upgrade the laptop that costs about as much as a ram stick.
https://linustechtips.com/topic/202529-terrible-laptop-help/#findComment-2748136
Your CPU is the part that's maxed not your RAM so your CPU is the problem, in short it's awful spend no more money on that laptop and save for a proper system.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/202529-terrible-laptop-help/#findComment-2748222
'Cause HP wants us to suffer...
https://linustechtips.com/topic/202529-terrible-laptop-help/#findComment-2748230
