A couple days ago I bought a Sapphire R9 280X Dual X Cooler, and when I try to load up Metro Last Light, I'm getting 16 fps on the lowest possible settings with no v-sync. Anandtech reviews shows that it gets at least 46 fps at 1080p. I tried it on my 1440 x 900 and still 16 fps. Anyone know what is happening, because I'm sure my card is not getting throttled or not enough power.
"Instinct or Rationality; Which will you choose? Enchanted by a superiority complex"
"what you do in spite of internet speed is inspiring. :3" From Cae - 2015
https://linustechtips.com/topic/202510-r9-280x-issues/
Is this the only game that its happening on? have you got the latest drivers?
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/202510-r9-280x-issues/#findComment-2747822
Drivers are AMD Catalyst Beta 14.7 RC3, OC to 1020Mhz, Memory 1600Mhz Fan speed set at 65%, Temps are 58 Degrees while playing metro,
https://linustechtips.com/topic/202510-r9-280x-issues/#findComment-2747883
First thing's first.
When troubleshooting a computer issue, always put everything back to stock speeds. No overclocks.
If it was factory overclocked, okay.
I would suggest that you try the 14.4 Drivers (non beta ones) instead. There have been reports of similar issues with the beta software -- it is beta after all...
Have GPU-Z (or Afterburner) running in the background, keeping an eye on the GPU and VRM temperatures.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/202510-r9-280x-issues/#findComment-2747924
The overclocks were factory overlocked, 14.4 Drivers made no difference.
https://linustechtips.com/topic/202510-r9-280x-issues/#findComment-2747942
I have managed to have no fps drop driving in Watch Dogs, yet Metro seems very taxing.
https://linustechtips.com/topic/202510-r9-280x-issues/#findComment-2748233
Strange .. I have Sapphire 7970 (which is the old name for R9 280X) and played the full Metro Last Light without issues ..
Try removing the driver totally (Uninstall), uninstall game, reboot, then install non-beta driver (e.g. 14.4) and re-install game ..
Question: What power supply are you using ?
Rig1LianLi O11 Dynamic Evo | Asus Crosshair VIII Formula | Ryzen 9 5950x  | 2TB Gen 4 | 64 GB  RTX 4090 | Samsung 49" 5120x1440
Rig2: TT Tower 200 | Asus X670e-i | Ryzen 9 7950X3D | 2TB Gen 5 | 64 GB  RTX 4090 | Samsung 57" 7680x2160  | Oculus Quest Pro
https://linustechtips.com/topic/202510-r9-280x-issues/#findComment-2748595
Does your card even go into 3D-Mode? I had some low framerates (10-20) sometimes, cause my r9 280x got stuck in 2D-Mode.
http://linustechtips.com/main/topic/201980-r9-280x-clocks-only-at-501mhz/
I disabled "Hardware acceleration" for the flashplayer, which might have caused this issue and so far it runs fine.
Ryzen 5 5600, 32GB DDR4, GTX 3070Ti, Acer Predator x34
InWin 901
https://linustechtips.com/topic/202510-r9-280x-issues/#findComment-2759084
Happened to me. Was a driver problem. Ended up having to reinstall windows to get it working proper again..
290x and at some scenes it would drop to 19 fps with 0% gpu usuage.
CPU -  Intel i7 4770k 4.6Ghz     Motherboard - MSI GD-65    RAM - Corsair Vengeance 16 GB     GPU - XFX 295x2    Case - NZXT H440
Storage - 256GB OCZ Vertex 4 ssd, 1TB WD Blue 7200rpm    PSU -  EVGA SuperNOVA 850 G2  Cooling - Corsair H80i     Keyboard - KGParadise v60 w/ cherry mx greens
Mouse -Theron  Sound - HyperX Cloud
https://linustechtips.com/topic/202510-r9-280x-issues/#findComment-2759419
Semi new build. Had it for three months since overhauling the components from AMD to a new Intel Setup. All hard drives were changed as well.. Old card was an R7 260X.
3D Mode is on. All other games get 50+fps. Watch Dogs even gets 80+ fps. Unigine Valley gets over 100fps maximum.
https://linustechtips.com/topic/202510-r9-280x-issues/#findComment-2763272
according to the specs of the mobo
2 x PCIe 3.0/2.0 x16 (x16 or dual x8)
1 x PCIe 2.0 x16 (x4 mode, black)
1 x PCIe 2.0 x1
these are the slots on the mobo you are using
make sure you didnt install the 2nd card on the black slot
use only slot 1 and 3
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/202510-r9-280x-issues/#findComment-2764457
now check your GPU and CPU temps
something is throttling the system
https://linustechtips.com/topic/202510-r9-280x-issues/#findComment-2765907
Use afterburner on screen display to check clock speeds while playing the game. The speeds should remain constant and not fluctuate. If it does fluctuate, despite reinstalling drivers and such, you may have a faulty card that requires RMA
CPU -AMD R5 2600X @ 4.15 GHz / RAM - 2x8Gb GSkill Ripjaws 3000 MHz/ MB- Asus Crosshair VII Hero X470/  GPU- MSI Gaming X GTX 1080/ CPU Cooler - Be Quiet! Dark Rock 3/ PSU - Seasonic G-series 550W/ Case - NZXT H440 (Black/Red)/ SSD - Crucial MX300 500GB/ Storage - WD Caviar Blue 1TB/ Keyboard - Corsair Vengeance K70 w/ Red switches/ Mouse - Logitech g900/ Display - 27" Benq GW2765 1440p display/ Audio - Sennheiser HD 558 and Logitech z323 speakers
https://linustechtips.com/topic/202510-r9-280x-issues/#findComment-2767421
