Little Help?
Solved by Guest,
I have looked at the KitGURU review as well as the OC3D review of the 1000W and they have come out pretty decent. Also here there is only a £20 difference in the cost between the G2 and the HXi so that wont really make too much of a difference.
The HXi looks to be a good psu, so I wouldn't try and dissuade you from going for it. Also you would need the EVGA P2 1000W if you wanted eco fan mode, as the G2 1000W doesn't have that feature. Also the P2 is a bit more expensive than the G2.
