So I'm probably gonna end up tucking my computer in my cabinet (like what Linus did with his HTPC), but I have a different situation. Mine is more open, but it still traps heat like no tomorrow. Here are the dimensions (going off the usable space, rounded to the nearest centimeter for you other folks):
  • 28 3/4" (73cm) wide
  • 21 1/4" (54cm) tall
  • 19" (48cm) deep
So, for the part I am uncertain about: where should I put the fans, and what size fans should I get (keeping it almost silent is my #1 priority). Crappy pic of the cabinet below, with my 300r where it would go. The cabinet is right against my dresser and the back wall, and the front fans on my 300r are intakes and the top two are exhausts.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/202191-cabinet-cooling-need-help/
2 Up on the top since the heat is going up and 2 and the bottom and 2 on the sides and 1 rear in the same direction that the cooler exhaust air so the additional fan can take the hot air out of the cabinet
upper ones>exhaust
bottom>intake
side>intake
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
21 1/4" (24cm) tall
I'd go with GentleTyphoons 800 RPM model, they're nearly silent and you would be able to run them at 100% all the time thus eliminating the need for PWM/resistors.
Any unknown button should be pressed even number of times.
Depends of how far your willing to go and whats the other computer?
Just my Dell which I fold with some times. It won't be there when I get my new computer going. Ghetto folding FTW.
I goofed on the conversion, didn't I? :P
upper ones>exhaust
bottom>intake
side>intake
Whoops, forgot to mention I can't put them in the roof of that part of the cabinet, since it's a multi-level deal.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
  • 21 1/4" (24cm) tall
  • 19" (48cm) deep
Take a look at the picture if you can;t in the top the side exhaust
Yeah, it's 54 cm.
Changed, musta hit the 2 key on my keypad by accident. :P
Side exhaust of the case?
BTW, there is about an inch or just under that between the side of the cabinet and the dresser.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
I'm not certain but I think the lower rpms the lower the noise (meaning bigger is better/moves more air at lower rpms) and don't use a filter, as it creates resistance, which will produce noise aswell. Just drill a hole in the top side of the thing and put some intake fans in front or do it the other way for negative pressure. Since hot air rises, the higher the exhaust, the better.
EDIT: Goes for intake aswell, the lower the better. Ugh, and aim the intake exhaust vs. the case's intake exhaust. Other will create turbulence which will produce noise aswell, though I don't think it matters much.
Yeah, it's 54 cm.
Just looked at your edit ( :mellow:), and the GT's are way out of my price range. I really don't want to spend more than $10 a fan if I have to.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Get some of these http://www.amazon.com/BitFenix-Spectre-200mm-BFF-SCF-20020KK-RP-Black/dp/B006VKAOOU/ref=sr_1_8?ie=UTF8&qid=1408743418&sr=8-8&keywords=200mm+fan two dollars over but should be quiet. Then drill holes in the wood and dont use dust filters as there should be dust filters on the case and maybe put some fans on the side window of the case for even more airflow.
Steve
Didn't they make Spectre Pro LED fans in that size? Cuz if there are any white LED ones... I'd consider dropping more on those.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
I dont know if its just the fan but my corsair led fan 140mm is sooooo loud. It dwarfs my reference 760 let alone my bitfenix fans that came with the case.(Which are much quiter) so im never buying a corsair fan or led fan. Bitfenix FTW
Steve
Spectre Pro's are Bitfenix silly. Only thing I will EVER buy from BitFenix are fans. LED strip started the death of my motherboard and soldered itself to my case.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
:o Im getting the shinobi for an upcoming build log mod thinghie magie. shhhh
Steve
I should have noticed they were bad sooner (they were really hot), but meh. Anyways, I'm down to these two (Newegg is the cheapest). I don't care that they're twice as expensive as I would like, I'll just buy them one at a time.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835345043&cm_re=bitfenix-_-35-345-043-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16835345044&cm_re=bitfenix-_-35-345-044-_-Product
Main rig on profile
VAULT - File Server
OptiPlex 7040M
What are bad? and do you have a fan controller?
Steve
I would get 1ap182 for back, and 1 for top
