Battlefield 4 start up problems
Go to solution Solved by colonel_mortis,
Do you have MSI Afterburner, EVGA precision, or anything else which uses RivaTuner Statistics Server running (In task manager, look for RTSS.exe and/or RTSSHooksLoader.exe)? I had loads of issues with crashing and lag while it was running, which were fixed once I managed to kill it. Note though that you may have to kill its parent as well (afterburner or precision) to stop it from instantly restarting it.
I start up battlefield 4 and get into a server but while I'm joining the server. Frames drop down to 4 frames and after it finishes with the loading screen nothing happens, frames drop down to 0 frames per second and the game crashes. Anyone have this problem or know a solution to it?
CPU: i7 3930k 4.5ghz CPU COOLER: Be quiet dark rock pro 3 MOBO: MSIx79a-GD45 PLUS RAM: G-Skill 16GB  GPU: MSI 780 TF  Storage: 2tb seagate and 60 GB OCZ ssd PSU: corsair CS750M
:D
https://linustechtips.com/topic/202071-battlefield-4-start-up-problems/
HTTP/2 203
Thanks! I had MSI afterburner in the backround and now its running perfectly fine!
:D
