When i oc my FX 8350 even by 100Mhz all the games that ran at ~40fps now run at 25fps. Even Black ops 2 fps drops. Dont tell me this is a heat issue, it cant be. I am using amd catalyst manager to overclock.
CPU: AMD FX 8350 | GPU: AMD R9 270 Windforce | MOBO: ASRock 990FX Extreme 3 | RAM: Kingston HyperX 8GB | Case: X Predator X1 |CPU COOLER: Hyper T4
NAZIS WILL RISE.
https://linustechtips.com/topic/201332-overclocking-cpu-lower-fps/
Correct me if I'm wrong but catalyst is for the graphics card ONLY right?
If you can though, how could it not be an issue? Obviously it is because it seems to throttle like a maniac when you OC it (That's the only explanation I can deduce from the info you have given us).
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
dont use that software
adjust the speed using BIOS
it called AMD overdrive
it works with AMD CPU and GPUs
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
You can oc both, but i used afterburner to oc gpu.
NAZIS WILL RISE.
Overclocking does not always give a positive result. Also, check your voltage, as your CPU could be unstable at that frequency, so try overdoing the voltage a bit, and see if that helps.
INTEL I7 4790K @4.6Ghz |  ASUS Z97-A  |  CORSAIR Vengeance Pro 1866Mhz 16gb | NVIDIA GTX 780 | NZXT H440 White | CORSAIR RM750 | SAMSUNG 840 EVO | WD Caviar Black 1TB | LIQUID COOLED |
Never knew it worked on AMD CPU's. Good to know (1 of my friends, the blasphemer, has an AMD CPU)
Can you tell me how? Do i just up the Multiplier or what?
NAZIS WILL RISE.
I didnt touch the voltage and i reseted the bios too. The fps lowers at all frequencys. Even at 100mhz oc - 4100Mhz
NAZIS WILL RISE.
If you increase the frequency, you have to increase the voltage as well in order for your CPU to be stable.
Instability will cause random issues with your CPU, which is why you are noticing the lower performance.
start with the by disabling turbo boost and enable cool and quiet mode
Disable APM
Enable HPC
Disable APM
Enable HPC
I will try to find those options but i didnt see them when i was checking the bios. One guy here http://forums.whirlpool.net.au/archive/970966 says to up the PCIE Frequency from 100 to 105~110. Should i try that?
NAZIS WILL RISE.
no don't adjust the PCI-E freq
those options should be under advanced options
you need to dig them
Cant find HPC. Is it high performance computing? cant find it. I looked everywhere. Not in OC tweaker, not in Advanced CPU configuration where Cool and Quiet was.
NAZIS WILL RISE.
Thanks everything works and oced to 4,2Ghz running smoothly.
"disable , spread spectrum, amd power app, cool'n quiet, c 6 state,
put the storage seting in ahci and ,bios ahci,
put the voltage near 1,46V~1.48v and the cpu multiplier to 24~25 and test it,"
Should i do this too? And what about Cool and quiet mode?
On skyrim at ultra setting and +20 mods and enb on 4,2Ghz my temp doesnt go above 40*C. Cooler - Zalman CNPS5X
NAZIS WILL RISE.
Do not throw 1.46v through your 990FX Extreme3. That 4+1 phase VRM will toast itself.
but what you think about "disable , spread spectrum, amd power app, cool'n quiet, c 6 state,"
My oc is good - 4.2Ghz with curent setting - apm disabled , spectrum enable, turbo disabled, cool and quiet enabled, c6 state enabled.
NAZIS WILL RISE.
You disable them for stability testing but I re-enable them when it's clear my OC is stable.
Your CPU might be good at those settings. But I would refrain from pumping too much Voltage through a board that is not designed for it.
Should i keep my current setting than? apm disabled , spectrum enable, turbo disabled, cool and quiet enabled, c6 state enabled.
NAZIS WILL RISE.
If it works I guess. What core voltage are you using for 4.2ghz?
1.3625V, going to test 4400Mhz.
NAZIS WILL RISE.
1.36 is safe, see how high you can get with that. My 8320 did 4.3ghz at 1.325 so I imagine you got some headroom.
