CPU cooler for oc
Go to solution Solved by Cacao,
Surprise surprise... I'm gonna recommend the CM Hyper 212 EVO
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU-聽i7 3930k @4.8GHz 1.4v聽-Mobo-聽Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz聽-Storage-聽500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse-聽Steelseries Rival聽-Keyboard-聽Corsair K70 Cherry MX Brown -Headphones-聽Audio Techinca ATH-M50 -Microphone-聽R脴DE聽NT1-A
https://linustechtips.com/topic/200768-cpu-cooler-for-oc/#findComment-2722162
Something from Be Quiet! or an AIO would do the job well and look nice.
Desktop: Intel Core i7-5820K, Corsair H115i, Asus X99-Deluxe/USB 3.1, G.Skill Ripjaws4 32GB 2800MHz CL16, Zotac RTX 3070, Samsung 950 Pro 512GB in Angelbird聽Wings PX1, Samsung 850 EVO 1TB, 5*Seagate 12TB, Cooler Master V1200, Phanteks Enthoo Luxe, Windows 10 Pro. Phillips 328P6VUBREB, Corsair Vengeance K95 RGB Cherry MX Brown, Logitech G502 X Plus, Sennheiser HD700.
AYANEO 2S: AMD 7800U, 32GB 7500MHz, 2TB WD SN850X. Windows 11.
https://linustechtips.com/topic/200768-cpu-cooler-for-oc/#findComment-2722165
Price range? The best is actually the Swiftech 220X, and it's 140$...
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/200768-cpu-cooler-for-oc/#findComment-2722170
corsair h105, kraken x61, and a noctua nh-d15 are good choices
My Current聽PC聽Codename: Scrapper
Intel i5-3570聽| Some LGA 1155 MOBO聽|聽Some Generic DDR3 8GB 1600Mhz聽|聽PowerColor RX 560 2GB聽|聽Recycled HP Case聽|聽Crucial MX100 128GB聽|聽1TB聽WD Blue 7200RPM聽| Some Generic 500w PSU聽| Intel Stock Cooler
https://linustechtips.com/topic/200768-cpu-cooler-for-oc/#findComment-2722183
If you want cheap and easy, go the Hyper 212 Evo. It's crazy good for the money.
If you're after something a bit fancier/nicer, you could always for an AIO such as a NZXT Kraken or Corsair AIO (whatever one you want, they're all good).
聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 Fractal Design Arc Midi R2 | Intel Core i7 4790k聽|聽Gigabyte GA-Z97X-Gaming GT 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽Notebook: Dell XPS 13
聽 聽 聽 聽 聽 聽 聽 聽 聽16GB Kingston HyperX Fury聽|聽2x Asus GeForce GTX 680 OC SLI聽| Corsair H60 2013
聽 聽 聽 聽 聽 聽Seasonic Platinum 1050W | 2x聽Samsung 840 EVO 250GB RAID 0聽| WD 1TB & 2TB Green 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 dat 1080p-ness
https://linustechtips.com/topic/200768-cpu-cooler-for-oc/#findComment-2722190
I would go聽http://au.pcpartpicker.com/part/gskill-memory-f314900cl9d8gbxl instead of what you have selected btw. This G.SKILL memory is faster, has the same CAS latency BUT runs on a lower voltage (1.5 as opposed to 1.65) which indicates higher quality components.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget聽http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 |聽http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/200768-cpu-cooler-for-oc/#findComment-2722223
Hyper 212X
SURPRISE MOFO
In all seriousness though, all the Hyper 212 (suffix) coolers are great. And the generational upgrade from the 212 evo is the 212 x, and I don't think they would sell it if the 212x performed worse than the 212 evo. Although it might be聽slightly more expensive
Home is where the heart my desktop聽is.
https://linustechtips.com/topic/200768-cpu-cooler-for-oc/#findComment-2722300
