My nexus 5 has been playing up on my WiFi at home everyother device is fine laptop, tablet, console all with the signal I am used to wherever I am in the house but with my nexus 5 it just low on signal everywhere I go unless I stand right next to the router. With my sisters phone the IPhone 4s I could be sitting next to her one room away and she's on full bars of WiFi connection buts there's me barely getting one bar of connection I was just wondering if anybody knew anything that would help. :)
https://linustechtips.com/topic/200604-nexus-5-wifi-issues/
Did it suddenly start this? Maybe after a software update or something.
If its like this when you bought it, I'd return it and get a new one.
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
https://linustechtips.com/topic/200604-nexus-5-wifi-issues/#findComment-2724762
its just suddenly happened I just got back from college and noticed my signal was very weak so I robooted my router Becuase its an old one now but change and I've tried booting into safe mode and still the same occurs :(
https://linustechtips.com/topic/200604-nexus-5-wifi-issues/#findComment-2724815
Try searching the XDA forums to see if anyone is encountering any similar issues. I think one of the updates 4.4.3 I believe did something to the radio on the d820 model. I'm running 4.4.4 on a d821 and have no WiFi or signal issues. You could try a factory reset though if you haven't.
@coen113
https://linustechtips.com/topic/200604-nexus-5-wifi-issues/#findComment-2724977
@coen113
I also run a d821 on 4.4.4. Odd... Maybe il try to figure out how to roll back
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
https://linustechtips.com/topic/200604-nexus-5-wifi-issues/#findComment-2725259
I remember one of the updates did something to the radio and many people had issues with it, I can't remember if it was model related or the LTE band or something. Is yours as bad? Like full bars as compared to 1 bar. WiFi stuff are pretty hard to isolate :/ it could be interference or something. Does it happen outside of your home network? Like maybe at office or a friend's place.
https://linustechtips.com/topic/200604-nexus-5-wifi-issues/#findComment-2725340
its always kind of bad, i dunno, i guess il wait for some updates, and see if that will help
https://linustechtips.com/topic/200604-nexus-5-wifi-issues/#findComment-2725519
