I have a SAPPHIRE HD 7950 graphics, when I try OC the GPU it wont take the OC at all no matter how small it is. I tried both AMD overdrive and MSI afterburner and no luck, i don't think my temps are holding me back as my GPU runs around 54c in games that i play.
if someone could help out I'd be grateful.
https://linustechtips.com/topic/200504-need-some-help-with-gpu-oc/
Set power limit to +20% then try upping the voltage to 1.25 (or VDDC = 1250, depending on software) then try continuing from there.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
