GPU problem: Snow
Go to solution Solved by MrKickkiller,
Had to Rma it, arrived faulty at my place
I seem to be having problems with my newly bought GTX 770 OC version from Gigabyte. I installed it in my PC, installed the drivers from the NVIDIA website and at random it starts to give me snow.
PC SPECS: I5-4690K
Asus Z97 DELUXE
Corsair RM 750
Corsair Vengeance Pro
Samsung 840 EVO
Gigabyte 770 OC2GB
Here is my screen when it 'crashes': http://imgur.com/ZO9uMZw
That time I saved Linus' WiFi pass from appearing on YouTube:
A sudden Linus re-appears : http://linustechtips.com/main/topic/390793-important-dailymotion-account-still-active/
https://linustechtips.com/topic/200311-gpu-problem-snow/
@MrKickkiller RMA it and get a new one. This is defective...
Owner of a top of the line 13" MacBook Pro with Retina Display (Dual Boot OS X El Capitan & Win 10):
Core i7-4558U @ 3.2GHz II Intel Iris @ 1200MHz II 1TB Apple/Samsung SSD II 16 GB RAM @ 1600MHz
https://linustechtips.com/topic/200311-gpu-problem-snow/#findComment-2715123
when i saw the title i was like WTF mine gives me fire...... any way is the gpu seated properly
Power cables for the gpu snugly in? GPU completely in the PCIe slot?
Power cables are well plugged in. I do think it is seated properly.
https://linustechtips.com/topic/200311-gpu-problem-snow/#findComment-2715192
Check the temperatures under load (e.g. valley)
The temperatures look fine under load.
https://linustechtips.com/topic/200311-gpu-problem-snow/#findComment-2715220
Then it's probably defective. As a last try check if the psu cable is defective by using another one (rm psus come with loads of cables right?).
sudo chmod -R 000 /*
https://linustechtips.com/topic/200311-gpu-problem-snow/#findComment-2715228
Squish it in the slot a little bit, just to be sure.
I did, now my hand is hurting ... xD Anyway i will run a benchmark in a couple of minutes.
https://linustechtips.com/topic/200311-gpu-problem-snow/#findComment-2715241
  • 3 months later...
https://linustechtips.com/topic/200311-gpu-problem-snow/#findComment-3478218
