Fan Connector Question
Go to solution Solved by MegaDave91,
okay thanks, what happens when i run out of fan headers on the motherboard? i cant seem to spot out many i plan to fill up all the spots so 2 fans front 2 fans for rad and 1 at the back.
 You can use fan splitter cables to run multiple fans off one header or run them straight off the power supply via 3 pin to molex cables.
I recently started my first gaming build with the MSI Z97 Gaming 5 mobo. I also bought another 2 AF140 fans. The motherboard only has 4 pin connectors while my fans are 3 pins it should work the same way shouldnt it? Case fans plug into SYS_FAN correct? so what should i plug into CPU_FAN? would it be the ones i hook up to the radiator?
CPU: i9-13900K |  MOBO: Asus ROG Strix Z790-E | Cooling: Corsair iCUE H150i Elite 360mm AIO | RAM: Corsair Dominator RGB 32GB 6200MHz CL36 DDR5 | GPU: Gigabyte RTX 4080 Gaming OC 16GB | Case: Corsair 5000D Airflow| PSU: Seasonic Prime GX-1300 Gold 1300W | Keyboard: Corsair K95 Platinum | Mouse: Logitech G Pro X Superlight 2 DEX w/ Powerplay
https://linustechtips.com/topic/199567-fan-connector-question/
3 pin works just fine in native 4 pin headers. The pump will plug into the cpu fan and the rad fans will plug into sys fan (should be a cpu optional header as well).
https://linustechtips.com/topic/199567-fan-connector-question/#findComment-2705285
Pretty sure you hook the CPU_fan to your pump, and radiator fans to system_fans.
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/199567-fan-connector-question/#findComment-2705290
3 pin works just fin in native 4 pin headers. The pump will plug into the cpu fan and the rad fans will plug into sys fan.
https://linustechtips.com/topic/199567-fan-connector-question/#findComment-2705295
https://linustechtips.com/topic/199567-fan-connector-question/#findComment-2705297
you can use a molex connecter for you fans from your power supply.
https://linustechtips.com/topic/199567-fan-connector-question/#findComment-2705300
You buy a fan splitter for a couple bucks.
There's also big connectors with molex plugs you can get, or fan controllers that go in your optical drive bays.
Personal Rig v3: AMD Ryzen 7 2700X | Noctua NH-U14S | Gigabyte B450 Aorus Pro ITX | Zotac GTX 2070 8GB | 16GB G-Skill Trident DDR4 3200MHz | EVGA Supernova 750B | Phanteks Enthoo Evolv ITX
Peripherals: Sennheiser HD518 & Classic ModMic | Corsair K65 Luxe | Zowie EC2 | ASUS VG259QM  |  ASUS VG278E | Klipsch ProMedia 2.1
https://linustechtips.com/topic/199567-fan-connector-question/#findComment-2705302
thanks
https://linustechtips.com/topic/199567-fan-connector-question/#findComment-2705303
thanks
https://linustechtips.com/topic/199567-fan-connector-question/#findComment-2705307
thanks
Anytime :)
https://linustechtips.com/topic/199567-fan-connector-question/#findComment-2705313
