Budget? Do you care how big it is?
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
I could start spouting things off like, 800/900D anything from CaseLabs, Kinda need a budget and desires
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
Just looking for ideals at this point.  Not really liking anything i am finding right now.
What have you found so far so we don't recommend something you have already looked at.
this is as close to 2x 360 on mass-production cases goes without modifications
and still have a decent budget for play-pretty things:
phanteks enthoo primo
switch 810: 9.25" x 23.43" x 23.03" (W x H x D)
enthoo primo: 9.84" x 25.59" x 23.62" (W x H x D)
basically .5" wider, 2.0" taller and .5" longer $90 more expensive over the 810
Looking for suggestions for a case that can fit two 360 rads. I currently have a 810 switch modded with two 360s in it, and looking for a change.
Enthoo Primo, 900D and Caselabs SM8 are the cases that come to mind.
Bert & Ernie before squirting spermie.
Hehe that's what I did with my Switch 810 as well. Good case.
Enthoo Primo - ASUS Maximus Formula VII - 4790k 4.8ghz 1.28v - EK Supremacy Evo Clean - 16GB Crucial Ballistix Tactical - 1000w EVGA Supernova Gold - 2x Alphacool Monsta Rads in push/pull - 2x Galaxy 780 HoF with EK waterblock
Build Log http://imgur.com/a/UV6Wh Just want to warn everyone, my build log is pretty mediocre.
How about a NZXT H440, 360mm up top and in front. It has kind of poor air flow but if you have a low ambient you should be good but if you use a 5.25" bay res/pump combo then it is not for you.
A water-cooled mid-tier gaming PC.
