Good morning everyone, first off thanks for taking your time to read/answer my post...greatly appreciated.
Soon ill be able to start my first build but I've few questions, I bought a generic case and sadly I've no idea how to determine whether its an ATX or ITX ( ill attach few picture s). If its an ATX which LGA 1150 mobo ( Asus preferred ) ( wont overclock ) under the 110 bucks range will I be able to pair with an i3-4150?. There is a fan slot, which fan should i get?( I currently have everything for the build but the mobo and processor ).
Again, thanks alot and have a good day.
post-120526-0-95929200-1408114799_thumb.
post-120526-0-42802600-1408114812_thumb.
post-120526-0-01934800-1408114822_thumb.
https://linustechtips.com/topic/198071-case-questions/
It is an ATX case. But that I/O panel is in a fixed position (i think) . Only a dremel will get that out.
https://linustechtips.com/topic/198071-case-questions/#findComment-2685750
Its that... Could it be?? My old Power-Up case? IT LOOKS EXACTLY IDENTICAL LIKE OLD COOP'S CASE
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/198071-case-questions/#findComment-2685761
It's an ATX case but its cheap, their is no cable management and a very cheap power supply. DO NOT GO PUTTING EXPENSIVE COMPONENTS INTO A CASE WITH A VERY CHEAP LOW WATAGE POWER SUPPLY THAT NOT 80 PLUS RATED YOU COULD VERY EASILY RUIN YOUR COMPONENTS
https://linustechtips.com/topic/198071-case-questions/#findComment-2685765
I agree. If a power supply is in included with the case, you may have to replace it. Inc. PSU has low wattage and more of a office power rather than OC and Gaming power
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/198071-case-questions/#findComment-2685791
Thanks alot for the replies. The I/O panel is removable quite easily but i didnt wanna remove it in case i had to return it, i am not using that power supply i am using a Thelmartake TR2 500w, the back panel is removable i might cable manage some.  So which mobo should i get?
https://linustechtips.com/topic/198071-case-questions/#findComment-2685810
Quite frankly it's not worth the hassle. If you already have a psu dump this thing and get a good case. It's already preset for a cheap comp and the more you have to fool with it the worse it will get. Get a Corsair 200R. $40 and waaay better build quality and usefulness. I can feel the cuts from the edges of this thing already.
Sir William of Orange: Corsair 230T - Rebel Orange, 4690K, GA-97X SOC, 16gb Dom Plats 1866C9,  2 MX100 256gb, Seagate 2tb Desktop, EVGA Supernova 750-G2, Be Quiet! Dark Rock 3, DK 9008 keyboard, Pioneer BR drive. Yeah, on board graphics - deal with it!
https://linustechtips.com/topic/198071-case-questions/#findComment-2686040
Question to OP, what brand is the case is?!?!?! I RLLY NEED TO KNOW. p.s where do you live?
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/198071-case-questions/#findComment-2686048
It just says "generic black and red case" lol no brand. I dont really care much for a "clean look-cable management" i just want a working PC and i cant really afford going for another case :'(. Does the motherboard come with the standoff? which mobo?
No, you can buy standoffs... Usually the case comes with a little box or a plastic zip-lock attached inside of it that will contain all the screws you need
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/198071-case-questions/#findComment-2686157
Yeah it did come with a plastic bag with a bunch of screws. Any H81,87 and 97 motherboard will work?
Lets just hope so.
(NOW)War Horse:
(WAS)Old Coop:
https://linustechtips.com/topic/198071-case-questions/#findComment-2686202
