Do I even need water cooling?
Go to solution Solved by TheRunningOtaku,
Stock fans should be okay, but if you want an upgrade get a 212 Evo
Watercooling is expensive, require more maintenance and take a long time to set up, not to mention the danger of leaks killing your system
They're a good idea if you *need* the performance, or enjoy watercooling, but personally I'd save the money and get a good air cooler (and maybe an SSD in that system ;) )
hey guys, i've never built a desktop with water cooling before
but it looks so cool, before I build it I need to know am I really need it.
AMD Kaveri A10-7850K
Gskill DDR3 PC19200 8GB GTX Dual Channel F3-2400C10D-8GTX
WDC 1TB SATA3 64MB - Caviar Blue - WD10EZEX
MOBO : MSI A55M-E33
Radeon R9 270X
with this system, would i really need water cooling?Im not gonna OC or other tweaking stuff(cause I can't)
I only want to play new games with high setting, my concern is I dont want to break my component due to overheat.
So am I gonna need WC or Stock fan is enough?
Regards
https://linustechtips.com/topic/197418-do-i-even-need-water-cooling/
You won't need watercooling for that. First of all, there are no R9 270X water locks besides universal ones, unless I'm mistaken, and if you aren't going to OC, a slightly better air cooler like the coolermaster TX3 or Zalman CNPS2X will do for the CPU, being quieter than the stock cpu cooler.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
*snip*
get a cooler master Hyper T4, 212x or a 212 evo. You don't need a water cooling loop.
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
Remember to be a good citizen and choose a 'best answer' when your problem has been resolved!
(that way people know when a problem's been resolved)
