HD 7870 for dual monitor setup help
o i c ty, what do u think about a dual crossfire setup for the hd 7870 or a single hd 7970, which is better.
what about the gigabyte hd 7870 oc version is it not as good as the msi one?
I would recommend a 7970 over two 7870s in crossfire, because of heat, space & scaling.
An overclocked 7970 is already almost twice as fast as a 7870 so you will have plenty of performance.
Also I don't recommend any Gigabyte or XFX card because they have locked voltage.
hmm i c i havent really tried the dual or triple monitor setup for gaming i just saw some vids and it looked really nice being surrounded by the game looked like a good idea so did u try the dual monitor setup and didnt like it? or u just dont like the idea about having that bezel?
Using three monitors in eyefinity can be really fun, but not two monitors, having that bezel in the middle of your field of view really destroys the experience.
If you want eyefinity get 3 monitors, otherwise just play on a single display.
