H100i infernal temps problem
Solved by ShadowCaptain,
That might be the problem... When i was installing the backplate it seemed a little loose, but when I placed the block on it it was pretty tight... Or wasn't? I will try to do something for that, i really hope that will help, thanks a lot
I will try and then post back, if you were right I will praise you as "The Mighty H100i Guru" u.u
Its the first AIO I have ever used, and I was sceptical. Yeah when I installed mine first time I could feel a little wiggle room and it did not seem to screw in as tightly as I thought it would so I added some washers and screwed it in further ( be careful you do not want to apply to much pressure because you could over-tighten
let me know if it makes any difference, it might not, but it helped for me!
