Helloo!
So i recently updated my shield to the newest software. But this new version on the shield hub does not display the shop, its just empty all the time, otherwise it works great. Anyone else had this problem? I´ve tried to restart the system, and i found out i cant uninstall the hub and reinstall it again..
any help?
Thanks!
Edit: oh yeah, is the game stream is still 30 fps? or am i just seeing thing?
CPU: Intel I5 3550 Motherboard: Maximus V Gene RAM: 8Gb Kingston HyperX Genesis GPU: Zotac GTX 670 Case: NZXT Vulcan Storage: 120gb Kintson SSD + 1TB WB blue PSU: Corsair CX600 Display(s): Asus 24" VE247H Full HD Cooling: Coolermaster V8 and Casefans Keyboard: Steelseries 6G V/2 Mouse: Razer Naga Molten Sound: Onboard + Astro a40
https://linustechtips.com/topic/195721-nvidia-shield-hub-not-working/
Pop onto the nvidia forums, there is some awesome help there!
Maybe try recovering your shield? Mine bricked itself during an update but someone from nvidia talked me through resetting my device. I did an update and I could no longer use the device. Since its an import I had no warranty so they talked me through it instead
