Hi guys, I'm about to order my GPUs but there is a problem: There are no reference EVGA 780Tis available in my country. I can only get the ACX versions. Can I fit reference style coolers on these cards? Are these cards built on the same PCB.
I'm in the local shop right now about to make the payment!
Thank you so much! :)
SimRacer - Casual FSX Pilot!
Mobo: MSI B550 Tomahawk | CPU: Ryzen R5 3600 | GPU: Vega 64 Sapphire Nitro | RAM: 16GB Crucial Ballistix DDR4 3200Mhz | PSU: EVGA P2 1000W 80Plus Platinum | Storage: 256GB Samsung 840 Pro SSD - 1TB WD Black - 2TB Seagate HDD | Cooling: Dark Rock Pro 3, Noiseblocker eLoop Fans | Case: Phanteks Enthoo Luxe | Audio: Sennheiser HD598 - JBL LSR305s | Display: BenQ EX3501R, Asus VG278H
https://linustechtips.com/topic/195719-need-help-urgently/
May i ask why ? the ACX versions are much better then the reference coolers
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654420
For SLI mate. Please don't ask why I'm about to make the payment here! :D
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654427
AFAIK it's a different PCB layout, but the ACX Cards would do much better for cooling.
I know they are better but I'll be doing an SLI setup. Please don't ask why, I'm writing these from a pc in my local shop here! :)
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654445
Please just tell me if I can fit a reference cooler on a 780 Ti ACX PCB...
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654457
No.......................
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654461
 Why?
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654466
The EVGA 780 ti ACX should have a reference PCB unless it's a classified card.
It's not a classified card. Here it is:
http://www.evga.com/Products/Product.aspx?pn=03G-P4-2884-KR
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654476
The PCB is the same, and yes I agree with you; the stock cooler is better for SLI.
INTEL I7 4790K @4.6Ghz |  ASUS Z97-A  |  CORSAIR Vengeance Pro 1866Mhz 16gb | NVIDIA GTX 780 | NZXT H440 White | CORSAIR RM750 | SAMSUNG 840 EVO | WD Caviar Black 1TB | LIQUID COOLED |
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654483
Thank you! :) So I can fit a reference cooler on it?
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654498
I'm pretty sure you can, I've seen a lot of people putting ACX coolers on stock Nvidia 700 series cards, so I'm sure you can put a stock cooler on an ACX.
Okay I've just had a look on the interwebs, the 780Ti ACX has a stock (reference PCB) BUT MAKE SURE YOU ARE NOT BUYING AN ACX FTW OR ACX CLASSIFIED (those have different PCBs)
Edited by heavygrounds
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654538
where are you going to get a reference cooler?
For an SLI setup on a case which doesn't have excellent airflow. An Obsidian 550D.
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654556
I'm about to order here lol this is so exciting. I can't be sure man can you show me some proof please?
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654570
http://pcpartpicker.com/forums/topic/42001-gtx-780-non-reference-cooler-replacement-possible
Cards with stock PCB:
EVGA ACX (but not the Classified or FTW)
MSI's TwinFrozr (technically aftermarket, but its just a stock design with better components)
Gigabyte Windforce (I believe it's stock, but I'm not sure. The GHz edition definitely isn't)
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654575
You are the man!!! Thank you so much! :) I'm ordering right now. Thank you again man.
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654587
No problem, glad I could help. Also, keep in mind that you will have to replace the thermal paste on the GPU core.
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2654597
no, I mean where are you going to buy them? I've never seen a site that sells just reference coolers, without the PCB attached to them.
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2655773
Oh, I'm sorry. From forums or maybe eBay... Water cooling guys usually sell their reference coolers and install a water block on the cards.
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2655800
I don't see why you would want to spend 80 bucks for a regular cooler when cooling doesn't even matter. Though I do like the look of the reference cooler better than the ACX.
CPU Intel i7-4770k @4.4Ghz Motherboard ASUS Maximus VI Hero RAM Corsair Dominator Platinum 1866Mhz 16GB GPU MSI GTX 970 GAMING 4G Case Corsair 760T Storage Samsung 840 EVO 250 GB + 2x WD Black 1TB PSU Corsair AX860 Display(s) AcerXB1, QNIX QX2710                         Cooling Corsair H105 Keyboard Corsair K70 Cherry MX Red + Red LED Mouse Logitech G700s Sound Beyerdynamic MMX300
https://linustechtips.com/topic/195719-need-help-urgently/#findComment-2655951
