So I've had my rig running for about 6 months and haven't had any huge problems, but for the past few months I've started to notice that the CPU is getting really hot, like up into the 90s. The build is as follows:
AMD A10-6800K (stock speeds)
Corsair H100i (push config)
Gigabyte GA-F2A85X-UP4
Asus R9 280X
Patriot Viper Xtreme (1x8)
Corsair Carbide Air 540
Ultra X4 750W PSU
I've tried resetting the BIOS to make sure it's not over-volting/overclocking the CPU, so the only thing I can guess at this point is software. Maybe I'm stupid, who knows lol. Any help would be appricated.
-John
https://linustechtips.com/topic/195575-higher-than-normal-temps/
Have you checked the voltage? If not download CPUZ and check it. Run something that's pushing the cpu where your seeing the 90's. Your looking for "Core Voltage".
Intel I5 4670k @4.6GHz // Corsair H100I // Asrock Fatal1ty Z97 Killer // Gigabyte R9 280x rev 2 // Sound Blaster Z
Evga 600b // 8G G.Skill Ripjaws X @2133Mhz // Corsair Spec-01 // Muskin Chronos 120G // Seagate Barracuda 1TB
https://linustechtips.com/topic/195575-higher-than-normal-temps/#findComment-2652877
Voltages seem fine, the highest it got was 1.334 volts. Stock is 1.3V, so it's probably the BIOS doing something. Sadly though I got it to 90 on Titanfall, and it's hard for me to get the game going and all that, so I'm running Prime-95 and Heavyload, and the temps are around 83. Is that normal temps for AMD? I know they ran hot but this is a little extereme.
https://linustechtips.com/topic/195575-higher-than-normal-temps/#findComment-2652914
Sounds like a thermal issue, replace paste if possible. Is the H100 new. Maybe not mounted properly? Or maybe the pump is dead=/
Think AMD rates it at 71.3°C max. Make sure your fans are blowing set them to 100%, then check.
https://linustechtips.com/topic/195575-higher-than-normal-temps/#findComment-2652953
Try thermal paste
THE LITTLE DEVIL : i5 4690k on NOCTUA NHD15
Asus z97 sabertooth mark 2
WD black 1TB & WD Green 2TB HDD, Samsung 840 Evo 240gb & Hyperx 240gb SSD
RAM- Corsair vengence 16gb and hyperx fury 8gb
PSU-Seasonic sII 620 wtt power supply
PErPHERaLS: Logitech g403 mouse, Redgear cherry MX brown switches, Logitech gamepad f310,Cosmic byte XXL RGB mousepad
Audio: SennheiserHD 558 and antlion mod mic
PHOnE: Realme 3 pro
https://linustechtips.com/topic/195575-higher-than-normal-temps/#findComment-2708023
Check and or user better Thermal paste and Make sure your FANS are connected correctly to your Waterblock, Depending where it is on your case you may Benefit from Intake or Exhaust.
Asus R9 280X
Ultra X4 750W PSU
-John
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
https://linustechtips.com/topic/195575-higher-than-normal-temps/#findComment-2709138
Check if the rad is full of dust. And put new thermal paste on
CPU: i7 4770k@4.3Ghz GPU: GTX 780ti Motherboard: ROG maximus vi formula PSU: Evga supernova 1000w Platinum
Case: NZXT Switch 810 Memory: g.skill ripjaws X Cooler: Corsair h100i(getting custom loop when i get money next) Storage: Samsung 840 evo 250gb Keyboard: Corsair K95 Mouse: SteelSeries Rival
https://linustechtips.com/topic/195575-higher-than-normal-temps/#findComment-2720895
Try this: check your rad for dust, change the thermal compound and check the pump is working, I have a h100i and can run an i5 3570K @4.2GHz with temps around the 60s so something sounds wrong for you. if you used stock thermal compound that came pre applied with the cooler I have had problems with it not spreading on the cpu properly so that may be the same fore you
https://linustechtips.com/topic/195575-higher-than-normal-temps/#findComment-2721735
