Hey guys. So I'm building my first gaming pc and i have experience building pc's so im fine with that but Im building the Austin Evans Photon Build which is recommended with an AMD Athlon X4 760X and A 8gb crucial ballistic Ram. Then on Newegg I found a bundle with an AMD A8-5500 trinity quad core APU and HyperX Fury Black Series 8GB ddr3 RAM. Also I eventually plan on getting a grapics card. Both the combo and the separate Athlon and Crucial are basically the same price. Would it be better for my pc to get the combo with the APU and different Ram and then get a graphics card or should I just stick to the Austin Evans Photon Build ? Links are below
AMD Athlon : http://www.newegg.com/Product/Product.aspx?Item=N82E16819113348
AMD A8-5500: http://www.newegg.com/Product/Product.aspx?Item=N82E16819113288&cm_re=AMD_A8-5500_Trinity_Quad-Core_3.2GHz%5c-_-19-113-288-_-Product
The Bundle : http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1766257
Hyper Fury Black : http://www.newegg.com/Product/Product.aspx?Item=N82E16820104444&cm_re=HyperX_Fury_Black_Series_8GB-_-20-104-444-_-Product
Crucial Ballistics : http://www.newegg.com/Product/Product.aspx?Item=N82E16820148540
Thanks
https://linustechtips.com/topic/195367-need-help-with-cpu-pick/
Thanks
Welcome to Linus Tech Tips!
I'd get the 750K and a dedicated GPU. The A8 is pretty much the same CPU portion, but it's locked, and includes integrated graphics really only good for low-settings gaming or HTPC use.
Also, HyperX Fury ftw
"Rawr XD"
https://linustechtips.com/topic/195367-need-help-with-cpu-pick/#findComment-2649827
You would better off with an i3 build, or even one of those G3528's and OC'ing it to ~4.5GHz.
As for the choices you've up forth, the Athlon would be better, and you can get slightly cheaper ram, i'd recommend this.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/195367-need-help-with-cpu-pick/#findComment-2649835
AMD Is love AMD is Life.
MY RIG | AMD FX-8320 | COOLER MASTER HYPER 212 EVO | ASUS M5A97 R2.0 | CRUCIAL BALLISTIX SPORT 8GB DDR3-1600MHz | WD CAVIAR BLUE 1TB | ASUS RADEON R9 280 3GB DIRECTCU II | CORSAIR 300R | CORSAIR CX 600W 80+ BRONZE | 1x COOLER MASTER SICKLEFLOW 120mm | WINDOWS 7 ULTIMATE 64-BIT | DELL S2240M 21.5' 1080p <p> | G602 | G710+ MOBILE| ONEPLUS ONE 64GB RUNNING OXYGENOS  | NEXUS 4 16GB RUNNING LOLLIPOP | NEXUS 7 2013 32GB RUNNING LOLLIPOP
https://linustechtips.com/topic/195367-need-help-with-cpu-pick/#findComment-2649985
