SP120's would look the best.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/194987-solid-looking-red-fans/#findComment-2644434
Got the red H440? What red fans should i put in the back of the case? Gonna be water cooling CPU but GPU is Air cooled
Fans that are red? Or red LED fans?
Fans that are red - not much to choose from, but the Corsair AF120/140's have red rings for them
Fans with red LED's - Corsair AF120/140's in LED form, Bitfenix Spectre Pro's or NZXT FZ's
"Rawr XD"
https://linustechtips.com/topic/194987-solid-looking-red-fans/#findComment-2644447
get some noctua fans and plasti-dip them red.
Or get some dye, it shouldn't affect airflow (idk about the 'dip)
How to Post Topics, the Right Way / The Ultimate Build Parts List
"4 words. DON'T BE A DUMBASS" ~@Swndlr
https://linustechtips.com/topic/194987-solid-looking-red-fans/#findComment-2644499
Links please
Just google SP120's?
https://linustechtips.com/topic/194987-solid-looking-red-fans/#findComment-2644561
Best choice. More airflow than Corsair fans, with less noise. Better static pressure as well.
Also, they can be taken apart for easy cleaning.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/194987-solid-looking-red-fans/#findComment-2644679
https://linustechtips.com/topic/194987-solid-looking-red-fans/#findComment-2644893
^this
Better than corsair sp120s and enermax magmas, and still red. They're identical to the noiseblockers e-loops, but they are coloured red.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/194987-solid-looking-red-fans/#findComment-2644981
^this
SP120 are actually pretty good, although the high performance ones are extremely loud, the quiet editions aren't half bad.
I've owned 8 gentle typhoons, 4 NF-F12, 6 Sp120 quiet editions, and the Sp120 are somewhere inbetween the two in terms of noise levels IMO.
Later down the road I may try E Loops if I ever do a white+black build or something like that.
https://linustechtips.com/topic/194987-solid-looking-red-fans/#findComment-2645020
