hi I have tried everythink with this board even sent it back they said it was working fine after they updated the bios got it back not working no post no bleeps no display can anyone tell me what memory I should be using on this board I am using 1866 8 gig
https://linustechtips.com/topic/194746-no-post/
Does anything at all happen when you hit the power button? Have you checked the pins on the CPU to make sure they aren't damaged? Did you try booting with no graphics card and just the onboard graphics?
Dubs are better than subs
https://linustechtips.com/topic/194746-no-post/#findComment-2640772
Is this a new build, or an upgrade?
"Any sufficiently advanced technology is indistinguishable from magic" - Arthur C. Clarke
Just because it may seem like magic, I'm not a wizard, just a nerd. I am fallible.
Use the quote button or @<username> to reply to people | Mark solved troubleshooting topics as such, selecting the correct answer, and follow them to get replies!
Community Standards | Guides & Tutorials Troubleshooting Section
https://linustechtips.com/topic/194746-no-post/#findComment-2641075
new build
Hmm. Assuming you've built a PC before, then I'd double check all cable connections and such. I;d take everything out of the case, and do a barebones build on top of the mobo box, with just the essentials to see if it will pass POST. If it won't, you need to check all connections, and start checking other HW to make sure it's not something else that's dead.
https://linustechtips.com/topic/194746-no-post/#findComment-2641361
yes I am just waiting on a new cooler to come as I have the h100i at the moment
Introducing new parts, to a system that can't POST with what is already has, is a bad idea. You're simply introducing more sources of error.
https://linustechtips.com/topic/194746-no-post/#findComment-2641779
but I cant test it out side the case with the h100i cooler that's why I am getting a nother coller
You can, if you just unscrew the rad from the case :P
https://linustechtips.com/topic/194746-no-post/#findComment-2641827
