I just bought 3x 3TB WD reds and want to put them in RAID 5 and I need some help
note: I have an ssd for the OS- this array will be for data storage
OS: windows 8
drives-
120GB hyperX 3k (windows 8)
3x unformated (brand new) WD 3TB reds
motherboard/chipset: gigabyte 990FX-ud3 (FX6350)
The motherboard supports raid 5 But I don't know how to add a hardware raid? Will i have to do a software raid through windows?
TekSyndicate Forum Moderator: https://forum.teksyndicate.com/users/njm1112
5930K@4.3Ghz | 16GB 4x4 2133Mhz | r9-290 | 6TB Raid5 | 250GB 850Evo | 8.1pro | RM750
https://linustechtips.com/topic/194560-help-im-making-a-raid-5/
Raid done by a controller on the mobo is still hardware raid, just not as fast or robust as a dedicated controller card.
You most likely need to go into the MOBO and switch the controller from AHCI (or even IDE) to RAID. But, before you do that, install the raid management software for your mobo.
Once switched in BIOS, should be able to create array..
If, after changing to RAID, system won't boot, just switch back and should boot and then can trouble shoot.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/194560-help-im-making-a-raid-5/#findComment-2637732
