Premiere Pro Problems
Pretty much, you'll have to run it through something like Handbrake to get it to sync up due to the footage recording at a variable frame rate.
Normandy - Intel Core i5 3470, 8 GB Corsair Vengenace LP, EVGA GTX 960 SSC, Gigabyte GA-Z77M-D3H-MVP, WD Blue 1 TB, Seagate 320 GB (steam), Seagate 320 GB (experimental, second OS, etc), Windows 8.1 + Ubuntu 14.10
Garrus - HP Stream 11
https://linustechtips.com/topic/193978-premiere-pro-problems/#findComment-2629570
But that's not the issue, I have been using Geforce Experience and it's just fine. I have a gaming channel and have edited hundreds of video, this has never been an issue before.
SO it used to work in premier pro and now its out of sync?
https://linustechtips.com/topic/193978-premiere-pro-problems/#findComment-2629629
Yes
Have you tried uninstalling and reinstalling premier?
Or is there a setting to revert all changes to factory default?
It sounds like an issue with the project settings you import the files into. Or maybe rendering settings...idk
https://linustechtips.com/topic/193978-premiere-pro-problems/#findComment-2630817
