it depends on your GPU actually
some may get higher clocks than others
but which model of your gpu you have?
for OC some models need the extra 6 pin power and better cooling
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/193961-max-overclocking/#findComment-2629334
What is the max clock you can overclock to when overclocking a GTX 750 ti?
It will vary depending on the card vendor, the cooler, and the actual chip itself.
With the 750Ti something to consider would be that cards equipped with the optional 6-pin power connector will overclock better then cards that don't have it.
"Rawr XD"
https://linustechtips.com/topic/193961-max-overclocking/#findComment-2629355
The one I am talking about is the EVGA GTX 750 ti. Not ACX or SC.
does it have the extra 6 pin power plug requirement?
if not
your OC may be limited to the PCI-E power draw
https://linustechtips.com/topic/193961-max-overclocking/#findComment-2629457
http://www.evga.com/Products/Product.aspx?pn=02G-P4-3751-KR
Here's the link to the model I am talking about.
yea i saw it already
your OC may be limited by the PCI-E lane power
https://linustechtips.com/topic/193961-max-overclocking/#findComment-2629513
So how clock can this card exactly push with the PCI-E and would a wind force be much better for overclocking?
we cant tell but the slot max power draw is like 75 watts
if you want to get better OC
you need to get GPUs with the extra 6 pin power plug
https://linustechtips.com/topic/193961-max-overclocking/#findComment-2629685
