Corsair H100i Temp problem?
Solved by Faceman,
LoL got almost 90c in occt with my fans at balanced
Whenever you run a stress test, set your voltage to manual before testing. I'm positive that you are leaving your voltage on adaptive while attempting to stress test and that is causing your high temperatures.
Still, go back and check the mounting on your H100i. Make sure it is mounted properly, and read the link I posted above in my earlier comment.
