Hey guys, I need some help with my pc parts Im going to buy at the end of the month. I do a lot of photoshopping and play games like Borderlands, Minecraft, Half life, Doom and all those. My budget is $650-700(at most since postage is around $50). I had the FX 6300 R7 260x 4 gb RAM (Will upgrade to 8) but I really like the Bitfenix Prodigy case, but AM3/AM3+ don't have any Mini ITX or mATX Motherboards, I was looking at going with Intel, but I wanted a Quadcore, and the i5 4460 doesn't fit in my budget, so I came up with this.
BitFenix Prodigy M - $109
ASRock FM2A88M Extreme4+ -$95
AMD A8 6600k - $115
Sapphire R7 260x -$155
Corsair CMX 1x4 GB RAM -$55
1 TB Western Didgital WD Blue -$69
Corsair VS550 PSU -$65
Total - $663
Tell me what you guys this of these parts, since I thought this would be better for my budget. I would rather not buy a Mid/Full tower since I normally bring my laptop down to the living room and hook it up to the TV and play Minecraft, and it would be a trek/10 to bring a Mid/Full tower down stairs, but since the Prodigy is small enough to fit on my desk and has handles, it would be easier for me. I also live in Australia and Im buying all my parts from PC Case Gear. Any help would be appreciated :) Thanks
https://linustechtips.com/topic/193482-700-aus-matx-build/
go for at least 8GB RAM
since you have a GPU
pick the Athlon 760K
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/193482-700-aus-matx-build/#findComment-2622729
I am from Australia and I dont think you can buy the 760k anywhere here. I will also get anther 4 GB stick for later upgrade. I know there are mATX Motherboards for AM3/AM3+ but there are also none from the place I am buying my parts from, and Im not willing to buy stuff overseas.
https://linustechtips.com/topic/193482-700-aus-matx-build/#findComment-2622802
http://au.pcpartpicker.com/part/asus-motherboard-m5a78lmusb3
MWave has it
but the VRMs are not cooled so you need to stick some heatsinks on them
or pick this
http://au.pcpartpicker.com/part/gigabyte-motherboard-ga78lmtusb3
but mATX AM3+ mobos are generally trash
https://linustechtips.com/topic/193482-700-aus-matx-build/#findComment-2622826
I've seen reviews of that Asus Motherboard and saw that it wasn't very good. What do you think of the specs I listed? I just want to know if it would be good enough for what I'm doing. Thanks
APU are only good if you don't need a GPU
and that APU is just borderline good, neither bad nor good
you will be better off with your current FX and a 270X
https://linustechtips.com/topic/193482-700-aus-matx-build/#findComment-2622854
I would if there was some better mATX  Motherboards for AM3+ :/ If I went with a FX 6300 and the R9 270x the price would bumb up to around $850, which is over my budget, and I wouldn't be able to get the Prodigy unless I got that Asus mATX which Im not keen on doing
https://linustechtips.com/topic/193482-700-aus-matx-build/#findComment-2622869
I linked another board which is the Gigabyte slightly better than the Asus
which parts you have currently?
https://linustechtips.com/topic/193482-700-aus-matx-build/#findComment-2622915
Do you mean which parts I have bought or which parts I have In mind of buying since I haven't bought anything yet because I want to make sure that I'm buying  the right parts for my budget.
the parts that you have bought or own currently
https://linustechtips.com/topic/193482-700-aus-matx-build/#findComment-2622950
Nothing, I don't have any parts bought yet. The only things I have for my new PC is a monitor, keyboard/mouse and a copy of Windows 7.
save up a bit more
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($78.00 @ Centre Com)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($39.00 @ Mwave Australia)
Motherboard: MSI Z97M-G43 Micro ATX LGA1150 Motherboard  ($129.00 @ CPL Online)
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory  ($95.00 @ Centre Com)
Video Card: Asus GeForce GTX 750 Ti 2GB Video Card  ($179.00 @ CPL Online)
Power Supply: Corsair VS 550W ATX Power Supply  ($65.00 @ Mwave Australia)
Total: $756.00
Generated by PCPartPicker 2014-08-07 19:15 EST+1000
this is a good start build
Pentium and a gtx750Ti
you can add a i5 down the line and a better gpu
https://linustechtips.com/topic/193482-700-aus-matx-build/#findComment-2623013
Thanks for that. I don't really want to buy parts from different stores so I'm buying them all from PC Case Gear. I've changed some specs and came up with this:
BitFenix Prodigy Mini ITX -$79
ASRock H81M-ITX - $79
Corsair 1x4GB RAM-$55 (Will upgrade to 8/16GB)
WD Blue 1TB HDD - $69
IntelCore i3 4150 -$129(Will upgrade to an i5 of some sort later on)
Total -$631
What do you think of that?
https://linustechtips.com/topic/193482-700-aus-matx-build/#findComment-2623075
Total -$631
pick a board like this
http://au.pcpartpicker.com/part/asrock-motherboard-h97mitxac
H97 chipsets will allow you to install the Haswell Refresh CPUs and the Broadwell CPUs down the line
https://linustechtips.com/topic/193482-700-aus-matx-build/#findComment-2623136
Ah sweet thanks, just switched them. The total is now $690, and $745 including postage which isnt too bad. Cant wait to build haha! Thanks for your help :)
no personal choice although I love MSI
see which is the cheapest for you
https://linustechtips.com/topic/193482-700-aus-matx-build/#findComment-2623202
Hey there 66Pyrithion,
WD Blue is a great drive that would do the job for you. But since you are going for some good gaming, I would recommend checking out the WD Black series which are designed specifically for gaming. Here's a link:
Hope this helps,
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/193482-700-aus-matx-build/#findComment-2624010
