As far as I know the coolant it self is rather unimportant. The main part is done by the radiators + fans.
ASUS ROG Strix B550-F + AMD Ryzen 5800X3D; ASUS 6800XT TUF; 16GB G.Skill TridentZ 3600; bequiet! Dark Power 13 850W; Samsung 860 Pro M.2 2TB; PHANTEKS Evolve X
https://linustechtips.com/topic/193022-best-liquid-coolant/#findComment-2616570
In terms of temperatures.. no it's not that important.
In terms of temperatures 6 months from now, important enough to care about.
Error: 410
https://linustechtips.com/topic/193022-best-liquid-coolant/#findComment-2616604
I want to liquid cool my pc and was thinking which is the best liquid coolant that can keep the temperature down, I know distilled water +silver is best still any other opinion is welcomed..... thanks in advance
I am working with water cooling already for a long time and I use distilled water with a silver kill coil and I can run a loop without maintenance up to 9 months... and then I just change it as a precaution.
You just have to make sure if you use aluminum parts to use an corrosion protection like anti freeze for a car. But other than that I rather use UV reactive tubes than a dye.
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/193022-best-liquid-coolant/#findComment-2616915
What will dye will do?If I use distill water +silver kill coil+dye is it ok? or should go for uv reactive tubes?.
https://linustechtips.com/topic/193022-best-liquid-coolant/#findComment-2617774
Dyes will break down over time and clog up your blocks and can stain your tubing. I personally would not use dyes either and always use distilled + kill coil.
https://linustechtips.com/topic/193022-best-liquid-coolant/#findComment-2617991
thanks man.is this pump good? MCP35X2 swiftech?
That is actually a dual motor solution - bit overkill. From swiftech the MCP655 is good the MCP35X is also a nice one.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/193022-best-liquid-coolant/#findComment-2618355
Water and Biocide,all you will ever need.
Preferably not silver,if the nickle strike is poor then you will eventually have corrosion of the copper substrate...leading to flaking.
The plating has to be perfect and greater than the 4 micron layer currently used by the likes of EK,Nickel needs to be 12 microns for proper corrosion resistance.
Wut?
Cooling is not reduced over time with DI.
SR-2-2x X5650 Xeons-3x 670 FTW-1x 120Gb Force GT-1x 240Gb Force GT-1tb WD Green-12Gb Dom GT 1866-Platimax 1500w-2x HK3-2xD5-24v controller-3x RX 480's-3x NiBlk HK GPU blocks-Koolance tops-BP res-15x SP120's-Little Devil V8.
https://linustechtips.com/topic/193022-best-liquid-coolant/#findComment-2625672
Wut?
DI? I'm talking about coolant exclusive of distilled/deionized because most people call those by proper names instead of the generic "coolant"
Pretty sure if you buy crappy 420swag colored coolant your performance is going to go down as the loop begins looking like the arteries of a KFC regular.
Error: 410
https://linustechtips.com/topic/193022-best-liquid-coolant/#findComment-2625954
I misunderstood,i thought your were talking about DI....
Last comment.....Yup.
https://linustechtips.com/topic/193022-best-liquid-coolant/#findComment-2626136
I wish there was a readily available anticorrosive additive I could add with distilled and biocide to call it a day. I am still wary of plating issues given how thin the nickel plating layer is on most blocks.
https://linustechtips.com/topic/193022-best-liquid-coolant/#findComment-2626143
