hi , i have some problem with my fps in most games , i get from 90 +  to 10 for 5-15 seconds , so i open gpu-z to see my gpu clock and my gpu usage , and the Performance Monitor to see the cpu usage and the cpu clock , and when i had a frame drop i saw that my cpu and gpu clock went down , so i disabled the cpu downclocking in the bios , but i keep having those drops , how should i remove the downclocking from my gpu ?
pc specs:
CPU: amd fx 8350 4.2ghz w/ cooler master 412s 2 fans
GPU: sapphire r9 280x oc
RAM: 8gb vengeance 1600MHz
MB: asrock 970 extreme 4
PSU: corsair cx750m
ps: i get more drops on war thunder
https://linustechtips.com/topic/192915-fps-problem/
Tenps
https://linustechtips.com/topic/192915-fps-problem/#findComment-2615026
my temps are fine , gpu not even at 64 c° and cpu 60 c°
it's written °C not c°
It's most likely thermal throttling, but If it's not thermal throttling.... I don't know what it could be, if the clocks are going down for no reason... could it be a set power limit?
https://linustechtips.com/topic/192915-fps-problem/#findComment-2615063
it's not thermal throttlin , my 280x it's well cooled .
https://linustechtips.com/topic/192915-fps-problem/#findComment-2615089
Lemme guess, beta drivers?
Roll'em back to certified ones. If you are on normal drivers already, try reinstalling.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/192915-fps-problem/#findComment-2615093
it's really annoying , because i tryed everything , since i started having those problems i changed almost everything , the only thing that i didn't changed is the cpu and the hdd ( and the case , but that doesn't matter ) .
another thing that's strange is that i started having those problems when i bought  a new monitor (benq gl2250) , but i don't think it matters.
edit : i tryed to unplug the new monitor an play on the old one , i still have those fps drops .
https://linustechtips.com/topic/192915-fps-problem/#findComment-2615209
Can you post a log (from afterburner or smth.) with gpu usage etc when under gaming load?
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/192915-fps-problem/#findComment-2615719
Run HWMoniotrn and see if you can check the temperatures for your VRMs on your motherboard. I'm suspecting they could be overheating and throttling your CPU.
The AsRock 970 Extreme4 uses a 4+1 power phase design....not very good --- especially with a over clocked FX-8350.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/192915-fps-problem/#findComment-2616061
this is what i have
post-10024-0-06076200-1407338761_thumb.p
https://linustechtips.com/topic/192915-fps-problem/#findComment-2616329
this is what i have
You need to find out what AUXTIN is.
Hopefully that is not for the VRMs...if it is, you have a VRM overheating issue.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/192915-fps-problem/#findComment-2616696
  • 2 weeks later...
