so i have two fans in my pc (not including the gpu, cpu, and psu) one of my fans is plugged into a molex adapter and the other is on the mobo.
i want to under volt (slow down) the one on the mobo. how do i do that?
its fan #1
ignore the max speed, it glitches out when you stop the fan.
anyways its running at like 1900 rpm, how can i get it to like 1500?
here is my pc/fan layout if it helps
post-45248-0-62745800-1407261845_thumb.j
this is a older pic, the current pc is more cable managed and i spray painted a few things
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/192528-how-to-under-volt-fans/
There are few options. You can set it from BIOS to silent mode (doesn't always work with 3pins). You can use software to control it, like Gigabytes own or HWmonitor/OpenHardwareMonitor. Or you can buy voltage limitator or low noise adaptor. They cost around $5. And then there's fan controllers.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/192528-how-to-under-volt-fans/#findComment-2614735
