My question is this at the moment i have an Intel i3 540 @3.07GHz and an EVGA GTX 750 1Gb, i really would like to play DayZ at a comfortable 35 to 40 FPS, would i need to upgrade my CPU or will the i3 do just fine and all i really need to do is adjust the Graphical settings. Thanks!!
https://linustechtips.com/topic/192387-best-cpu-for-dayz/
I'm sorry, but I don't think that the CPU upgrade is going to let you play at 35-40 FPS.
I have a 4670K, overclocked, and a R9 290. Even on my computer, I have to turn the settings way down, to get about 30FPS max.
Right now, the game has terrible optimizations, so we'll have to wait until the final game releases (because right now, you can get it on Steam in Early Access), because the game runs so bad right now.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/192387-best-cpu-for-dayz/#findComment-2606417
DayZ and ARMA 2/3 are terribly optimized. If you want the best CPU for DayZ then choose the best CPU money can buy.
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
https://linustechtips.com/topic/192387-best-cpu-for-dayz/#findComment-2606553
