Wanting to choose RAM - Help?
Go to solution Solved by Clyne,
But what kind of RAM? I considered Corsair Vengeance Pro but a lot of people I know said it was terrible. I also will be using Adobe Premier Pro a lot.
Kingston HyperX Fury 16GB 1866mhz  You can chose from red, blue, black, and blue colors.
I've started the process of ordering parts for my new PC I'm building but I can't decide what type of RAM to get, I know I want 16GB but I don't know what RAM I should get, so can anyone help me?
In case you need to know these are the parts it will go with:
NZXT H440 Case
Corsair AX860 PSU
Asus Maximus VII Hero Motherboard
Intel Core i7 4790k processor
Corsair H100i CPU Cooler
EVGA GeForce GTX 780ti GPU
Seagate 4TB Hard Drive
Intel 730 Series 240GB SSD
Windows 8.1
Also, for this rig I will mostly be playing games and editing videos and using photoshop frequently.
Thanks!
Magna
Check me out on YouTube
http://wwww.youtube.com/osirisalive
https://linustechtips.com/topic/192199-wanting-to-choose-ram-help/
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Get 16gb of ram at 1866 mhz. Should be good for gaming and phototshop.
@Magna any dual channel 16GB kit will do. Normally aesthetics isn't a concern when choosing unless you have a lot of money/are picky(like me)
Try to aim for a 1600mhz frequency as a base, 1866mhz is quite nice 2133mhz. Low cast latency = CL 9-11 is fine.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
