Need Help With My Website
Go to solution Solved by OrangeFlavoured,
Put it inside a div with a unique ID attribute, then in your CSS, do
text-align: center;
Or,
margin-left: auto;margin-right: auto;
I want to embed my Twitch.tv player from my channel on my website, I can do it, but the player isn't centered. How can I center it?
https://sites.google.com/site/therainingpixel/
The code:
<object xmlns="http://www.w3.org/1999/xhtml" bgcolor="#000000" data="http://www.twitch.tv/widgets/live_embed_player.swf?channel=therainingpixel" height="378" id="live_embed_player_flash" type="application/x-shockwave-flash" width="620"><param name="allowFullScreen" value="true" /><param name="allowScriptAccess" value="always" /><param name="allowNetworking" value="all" /><param name="movie" value="http://www.twitch.tv/widgets/live_embed_player.swf" /><param name="flashvars" value="hostname=www.twitch.tv&channel=therainingpixel&auto_play=true&start_volume=25" /></object>
https://linustechtips.com/topic/191472-need-help-with-my-website/
text-align: center;
Or,
would margin: 0 auto; work as well, 1 less line!
@Raining_Pixel
also what are you trying to do to yourself on may 20th, 2015!? Kill yourself!?
over 70 hours a week of skyrim, are you insane  :huh:
It would probably work ( I haven't testing it) but it would be bad because you are setting the top margin to 0 (which may counteract other settings) and then only setting the right. Bad Idea.
I have no idea what you are talking about in the 2nd paragraph...
Roses are red, violets are blue, computers are awesome, and so are you!
the second paragraph was about in the op's website in the on his twitch channel he says he's going to play skyrim everyday for hours on end.
Oh OK, I didn't understand cause you said it while quoting my reply :P
you can put at the beginning of the code and then at the end also if you want to make the code even cleaner.
For example This text will be center-aligned.
Actually the center tag is deprecated, and is considered bad practise
The CSS solution is to prefer
This is the case with all formatting, I believe. HTML should no longer be used for any of that. HTML is purely for content flow/structure... CSS does the Look and Feel...
@Raining_Pixel
Can't get enough Skyrim. ;)
