Get a SSD in that price range 100%
The 780ti will perform exactly the same as a titan black in gaming applications. That would be a huge price cut.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/191067-build-price-help/#findComment-2578806
http://pcpartpicker.com/user/Phllips/saved/ytXYcf this will destroy that in games
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/191067-build-price-help/#findComment-2578836
If you're gaming,
http://ca.pcpartpicker.com/p/jQBNxr
Will work just as well, and will be much cheaper.
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/191067-build-price-help/#findComment-2578861
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($364.98 @ Newegg Canada)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler ($104.99 @ Memory Express)
Motherboard: MSI Z97-G55 SLI ATX LGA1150 Motherboard ($136.98 @ Newegg Canada)
Memory: PNY XLR8 16GB (2 x 8GB) DDR3-1600 Memory ($180.48 @ Newegg Canada)
Storage: A-Data Premier Pro SP900 256GB 2.5" Solid State Drive ($168.32 @ Amazon Canada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($54.99 @ Canada Computers)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card (2-Way CrossFire) ($409.99 @ NCIX)
Case: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case ($109.99 @ Memory Express)
Power Supply: SeaSonic X Series 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($189.98 @ Newegg Canada)
Total: $2115.69
Generated by PCPartPicker 2014-08-03 02:47 EDT-0400
You could even go cheaper if you wanted http://ca.pcpartpicker.com/p/czrJmG, that will be plenty at 1440P
https://linustechtips.com/topic/191067-build-price-help/#findComment-2578955
Replace the stock fans on your h100i and replace them noctua fans.
Noctuas are loud, if he were to replace them he should replace them with SP120 quiet editions
That will be more expensive than his current build which he wanted to be cheaper
https://linustechtips.com/topic/191067-build-price-help/#findComment-2578972
