Ok guys i need some help. i need to find the drivers to install the integrated graphics on my asus m5 a7 8l- m usb 3.0. The reason why i need this is so i can try to get a third monitor on my pc and i read you can do it by using both the gpu and the onboard gpu so now i need to find the drivers for the onboard. Thanks you all very much.
I run my own indie game company called Color Dragon Studios where we are currently making a 2d platformer game called Small Earth.
https://linustechtips.com/topic/190936-intergrated-graphics-help/
when you use your GPU to output video, your onboard video is usually disabled
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
http://www.asus.com/Motherboards/M5A78LMUSB3/HelpDesk_Download/
Select your OS, go to 'VGA' download that and install.
which one is the integrated gpu
if you are only using AMD graphics solutions, you just need the Catalyst driver, my friend.
if you just want it to work then install the drivers from the disk in your mobo box.
How do i know what integrated graphics i have on my mobo? sorry and thanks.
if it's an AMD processor then you will be using AMD graphics.
hop on to the AMD website and install Catalyst
http://support.amd.com/en-us/download/desktop?os=Windows+7+-+64#amd-catalyst-packages
Compatible with Windows 95
from the motherboard specifications:
Integrated ATI Radeon™ HD 3000 GPU
Multi-VGA output support : HDMI/DVI/RGB ports *1
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 2560 x 1600 @ 60 Hz
- Supports RGB with max. resolution 2560 x 1440 @ 75 Hz
Maximum shared memory of 1024 MB
Hybrid CrossFireX™ Support
*1: Support dual VGA output: HDMI & RGB, DVI & RGB.
*2: Refer to www.amd.com for the Hybrid CrossFireX selected GPUs.
source=http://www.asus.com/Motherboards/M5A78LMUSB3/specifications/
