My h100i has accumulated a bit of dust in the radiator and my electric duster doesn't quite cut it. Would be possible to pour water through it (from a sink) to clean it?
im pretty sure dust is hydrophobic meaning the water is repelled best way is a good blow with your lungs or an air duster
5820k@3.8GHz| Corsair H100i |Gigabyte x99 SLI | Corsair 16GB | EVGA 780Ti SC ACX SLI x2 |240GB SSD120GB SSD 512GB SSD 2TB HDD | 3x ASUS VN247H 24" ( nVidia Surround)
https://linustechtips.com/topic/190830-cleaning-a-radiator/#findComment-2575201
I wash the fins of mine with a pressure washer whenever i take it out the case. Dont hold it too close and you wont have any problems.
https://linustechtips.com/topic/190830-cleaning-a-radiator/#findComment-2575332
Take it in the shower with you,job done.
SR-2-2x X5650 Xeons-3x 670 FTW-1x 120Gb Force GT-1x 240Gb Force GT-1tb WD Green-12Gb Dom GT 1866-Platimax 1500w-2x HK3-2xD5-24v controller-3x RX 480's-3x NiBlk HK GPU blocks-Koolance tops-BP res-15x SP120's-Little Devil V8.
https://linustechtips.com/topic/190830-cleaning-a-radiator/#findComment-2575640
You can wash them, but I personally use an air compressor at home... it´s fast and easy :) .
Intel i7 7820X (delidded) @ 4.9GHz - MSI X299 M7 ACK + EKWB Fullcover Block - G.Skill Trident Z 32GB @ 3466MHz - nVidia Titan Xp + EKWB Fullcover Block @ 2.1GHz - Samsung 960Pro 2x - WDD Blue 2TB - Seasonic 750W Platinum - modded Corsair 600C - Hardtubed Custom Watercooling
https://linustechtips.com/topic/190830-cleaning-a-radiator/#findComment-2575807
