So I've been messing around with project spark and cryengine, but i dont like project spark because its kind of limiting, and i love cryengine, but it seems apparent to me that even though it is possible to make a third person game, it would be a pain in the butt because its more of a fps engine. What engine could I use to make a third person game but have the ability to switch between first and third person at will fairly simply? I want it to have elements from games like assasains creed and tomb raider, but be able to switch it into classic fps mode at will, kinda like skyrim. Any ideas?
https://linustechtips.com/topic/190741-suggest-me-a-game-engine/
i only have experience with unity but either way its not dunno be very easy to achieve.
Listen if you care.
https://linustechtips.com/topic/190741-suggest-me-a-game-engine/#findComment-2573737
Unity is probably better for you, its free and you can try it out for yourself. Also theres more documentation for Unity.
Muh rig: i7 4770k, Cooler Master Hyper 212 Evo, MSI Z87 G45, Kingston Hyper X Blu 8GB, Samsung 840 EVO 120 + WD Blue 1 TB, Asus GTX 770 2GB, Corsair 200r + 2x Corsair AF 120 Blue + 1x Stock corsair fan, Corsair TX650, LG 27EA33V IPS, Steelseries Sensei Raw + QCK mini, CM Quickfire Ultimate Blue.
https://linustechtips.com/topic/190741-suggest-me-a-game-engine/#findComment-2573791
Darkplaces is an open source engine (think Quake on steroids).  I used to play Nexuiz 2.5.2 which used it and there were some setting for first and third person.  You can even get a blender addon that uses this engine for rendering.
1 Timothy 1:15
https://linustechtips.com/topic/190741-suggest-me-a-game-engine/#findComment-2574758
For an indie, I highly recommend Unity3D or Unreal Engine 4. If you don't want to pay for your engine, there's a free version of Unity3D and the Unreal Development Kit, both of which have TONS of tutorials and tips all over the internet.
I started with Unity, then moved on to CryEngine. It's not as hard as you'd think to make a 3rd person game, all you have to do is change the way the camera is attached to the "Player" actor. After a while, I found CryEngine to be an optimized mess, so I tried UDK. It was pretty sweet, so I bought UE4. Haven't looked back since.
Intel Core i7-4930k @ 4.4GHz; ASUS Sabertooth X79; Corsair Vengeance 64GB (8x8) 1866MHz CL9; ASUS R9 290X 4GB; ADATA SX900 Pro 128GB SSD, Seagate Barracuda 2x2TB RAID 1, Western Digital 3TB My Cloud; Corsair RM1000 80+ Gold; Corsair Graphite Series 760T 760T; BenQ XL2420T 120hz
"Stay moist." - Iron Claws, Elder Scrolls Online
https://linustechtips.com/topic/190741-suggest-me-a-game-engine/#findComment-2578089
